1971 frame off
Old Mar 15, 2010 | 03:04 PM
packlite's Avatar
packlite
1971 frame off
Im new here so bare with me.I want to move shocks to outside frame in rear, is this a real problem? also put fuel tank under frame where spare tire went. thanx keith
Old Mar 15, 2010 | 04:47 PM
jowilker's Avatar
jowilker
You might want to look at a 73-79 chassis. Everything is swappable with the gas tank between the rails already, plus it will have power disc brakes and steering.
The 73-79 chassis is 4 in longer (all under the bed) cab & front clip are bolt hole exchange.
Is OK if you have a plan already.
John
Old Mar 15, 2010 | 08:13 PM
frankensteined_67's Avatar
frankensteined_67
for the gas tank look at this article. it is for a 53 but it still works for the 67-72 trucks. many ppl here have done this but it does put the filler in the bed unless you can get a little creative and move the filler to the side of the tank.
Installing a Mid-60's Mustang Gas Tank In A 1953 F-100 .: Articles
for the shocks i take it you are thinking of the newer f-150's. dont know what rear end you have. but the 67-72 are not wide enough to do so. the shock will hit the tire (they did on my mock up i did) the 73-79 axles are wider then the 67-72. you might try one of those. you will need to move the spring hanger on the axle and more the shock hanger on the frame to the out side. (i dont know if it will interfere with your tire or not).
on a side note: if you have a 2x you can transfer the whole i-beam/spindle and rad bar assemble from a 73-79. as well you will need the p-valve and power booster and master cylinder. ( your steering will not meed to be modified to do this swap it is a direct bolt up swap.)
if a 4x4 you just need to get the spindles off the same size axle most people use the chevy's because you can do the high steer kit and they are stronger then the ford's model.
good luck and let us know.
Old Mar 22, 2010 | 09:19 PM
packlite's Avatar
packlite
thanx alot yall !!
Old Mar 23, 2010 | 07:08 AM
4x4jedi's Avatar
4x4jedi
I havnt looked at prices yet but what about a fuel cell???
How much is the mustang tank vs fuel cell???
I want to do the same thing but I'm not even close to that point on my truck. I'm still straitening out my cab
Old Mar 23, 2010 | 04:18 PM
frankensteined_67
fuel cell's are almost twice as much as a new mustang tank. and in most states fuel cells are illegal as well. here is a web site that has all diferent makes and models of stock tanks. as well as the measurements of them.
Quanta Products
(mustang tank 16 gal.)Quanta Products-Cougar, Mustang, 1964 - 1968
you might want to look at the chevy blazer 1973 tank looks like it would fit and its a bigger capacity too.
Old Mar 23, 2010 | 06:45 PM
4x4jedi's Avatar
4x4jedi
Awsome tidbit. I'm in PA. I have friends running cells. I'm not shure if it's legal but they get away with it
truckerdead
13
Sep 10, 2013 10:01 PM
Samsn4
Sep 28, 2012 09:29 PM
shorttop50
Feb 16, 2005 07:54 PM
cjcathey2002
Aug 15, 2002 06:18 PM
StockMan
Aug 2, 2002 11:46 AM
