2001 f250 7.3 today the blower motor stays on when key is off and out of the truck air bag light stays on with key off radio-cd player only plays through the speckers when the clutch switch is pushed in started it and the dinger keep dinging i figure i got me a short or a back feed but thought some body might know something (i did disconed the ingntion wires did not chang and all relays and fuses are good) would like to get a good spot to start looking if noghing more thanks
got it the fuse box in the cab had moisture in the wire harness on the drivers side dryed it out with my little girls pink hair dryer and now its fine so if you get any crazy problams in the cap check the wire harnes hook ups or the gem ontop of the fuse box but they are about 500 bucks
