1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Searched with no luck. Please help
Old 03-14-2010, 08:55 PM
mossy33oak's Avatar
mossy33oak
mossy33oak is offline
2004 F-250 Sport Crew Cab (5.4 L if that matters) I currently have BF Goodrich 295x75x16's on my truck (bought them in 04 and got 65k miles and 5 winters out of them) I am buying new tires this year and am looking for some assistance. I would like to possibly go up one ties size (as my wheel well still looks not full). I do zero towing, and the only thing my truck is used for is hunting. She has seen quite her share of mud holes. The only road use she gets is to and from the woods. Can I go with the 305x75x16 or 305x70x16? Any help would be appreciated (or other recommendations of sizes that will work.) I am happy with my BFG's, unless someone can suggest a suitable replacement. Thanks guys!
Old 03-14-2010, 11:34 PM
redford's Avatar
redford
redford is offline
Received 1,629 Likes on 953 Posts
305s might be a bit too wide for stock wheels.
Old 03-15-2010, 11:40 AM
mossy33oak's Avatar
mossy33oak
Thanks, does anyone know if this is true? What is the biggest I can fit on my stock rims?
Old 03-15-2010, 11:46 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
First, find out what rims you have, they should be 7" wide rims, if they are the stock 16" wheels.
Then, look at tire specs. They all have a recommended, and min/max rim width.
Old 03-15-2010, 12:37 PM
Rando Commando's Avatar
Rando Commando
Rando Commando is offline
You could always get a tire with a higher sidewall aspect ratio, however I believe you might have trouble finding them.
You can figure out tire sizes with some simple math. Let's take your tire, for instance: 295/75R16.
295 is the width in mm of the widest point at the sidewall. To convert to inches you must divide by 25.4. So 295/25.4=11.6".
Next you have the sidewall aspect ratio. In this case the number is 75, meaning the sidewall is 75% of the width. 11.6*.75=8.7"
To get the overall height you take 8.7"*2=17.4"+16" for the wheel=33.4".
Now, I'm not sure if you have any sort of lift on your truck, but generally 33" is the biggest you can go on a stock height. 2" or so of lift will get you to 35".
Old 03-15-2010, 01:08 PM
midnightrider32's Avatar
midnightrider32
midnightrider32 is offline
Edited for krewat
Old 03-15-2010, 01:54 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Let's keep this to the 2004 and before years, 2005+ are different suspension, and different rims entirely.
AmerigoHauler
06-07-2013 06:22 PM
FordF350Baby
15
11-11-2007 05:01 PM
Hardrock_F250
10-01-2007 09:02 PM
kippercal
10-11-2006 11:13 AM
chadrock
1997 - 2003 F150
04-26-2002 08:05 PM
Quick Reply: Searched with no luck. Please help
