i purchased a fuel filter kit for my 6.4l motorcraft of coarse. changed this filter at 20000 miles and both filters in the kit looked as did original. at 40000 miles purchased kit and lower filter has an o ring seal at the the bottom. i know it is an updated design, but has anybody had problems installing. put new filter in cap and proceeded to install, tighted cap up, but flange would not sit flush to housing like when the original designed filter was installed. put old filter in just till i find out if this is normal, did not want to over tighten. sure would be nice if they gave you a little more room to work.
Just installed the updated one on my 6.0 and had no problem getting the cap to seat fully. Got another 1K miles before the 6.4 needs oil and fuel changes.
the 6.0 uses a differt filter kit fd4604 the 6.4l used a fd4609 filter kit there is an updated filter for the hfcm module filter that has an extended flange with an oring on it, has anyone had a problem installing the updated filter, mainly does the cap flange meet flush with the housing with the updated filter, mine did not, but it did with the old style filter.
