55 or 56 F600
The body style is different between the 55 and 56 Ford trucks. If it has a 55 grille, and the slanted windshield, instead of the wrap-around, then it's a 55. My understanding is the 12 volt changeover came with the model year change, so unless Ford did things differently with the bigger trucks, (ie, your F-600) it's more likely to have been converted. And that certainly wouldn't be unusual.
All bets are off on the really big trucks, F-700 and larger. The 600, I wouldn't swear one way or the other, but I suppose it wouldn't surprise me, either way. The 73-79 big trucks have the 67-72 dash in them, and I've seen late 90's model big Fords with the 80-86 dash. Here's a 68 F-800 dump truck, that came factory with the 66 style cab. I've seen these up to 69 with the old style body on it.
68' FORD F800 PICKUP, DUMP BODY | Howell | Kijiji | 704197
For the 55 or 56 thing, the vin will tell the tale.
I know for a FACT Bigger trucks got usually the Body Styles 1 down from them. or they kept the same Body Styles Longer,
Meaning a '67 F-600 will have a '61-'66 Cab.
A '73 F-550 will have a '67-'72 dashboard in it, with Bigger Fenders to accommodate the tires and a different grille.
Only the 1967/69 F800/1000's used the 1961/66 cab, as did 1967/69 N/NT/T500/1000's, and...
1961/66: There were TWO different cabs.
1) 1961/64 F100/1100 / 1961/66 N/NT/T500/1000 / 1965 F100/250 4WD / 1965/66 F350/1100 / 1966 F250 4WD (1967/69: F800/1000 & N/NT/T500/1000).
2) 1965/66 F100/250 2WD / 1966 F100 4WD.
In addition, some 1966 F/N/NT/T500/1000's had a raised roof.
There was no such thing as a F550 back then.
Originally Posted by 76f350spercamprspeal
The Next years body styles are usually made in June.
New vehicles historically are introduced in September of the previous year.
There are exceptions: 1965 Mustang (4/1964) / 1969 Econoline (2/1968) / 1969 Mark III (3/1968) / 1970 Maverick (6/1969) / 1983 Ranger (3/1982).
Ford had assembly line difficulties with the new 1957 trucks, which were not introduced until January of 1957.
Ford continued production of 1956 trucks past August to fill the gap until the '57's were introduced (info source: Pickup Trucks by Mike Mueller / MBI Publishing / ISBN 0-7603-1842-5).
There is no parts catalog listing for a 1953/55 windshield used in a 1956 truck, excepting Parcel Delivery's that changed very little from 1951 thru 1975.
Originally Posted by 76f350suprcamprspeal
The Next year's body styles are usually made in June.
The model changeover begins in late July or early August, not in June.
Thanks Numbers for the insight. I don't have much knowledge of the auto biz and I'm still a bit confused. The truck in question has a delivery date on the ID plate of 9/30/55. It is a F600, is 12 volt that looks original and has a 55 cab. It was delivered to the military. Would a military truck have made any difference between time built and time delivered? Could they have built some trucks with 55 cabs and 12 volt electrics after the 56 model year started? or would they have built some trucks in 1955 with 12 volt electrics per order and not delivered them to the military until 9/30/55.
Thanks,
Greg
Thanks,
Greg
1) When new vehicles are introduced...unless the dealer is very fortunate, there will be some of last years models still on the lot.
2) Military contracts can take a long time to fill. In what month (or year) was this military contract first tendered? How many trucks were involved?
3) It's possible the contracted trucks were stored on a FoMoCo storage lot. And then...when the last truck was assembled, all of them were delivered on 9/30/1955.
The Gov't specifies how vehicles are to be built under their contract. This is the reason a '55 could have a 12 volt system.
Some of these trucks came with Leece Neville alternators. The first Ford vehicles with standard equipment alternators were 1963 Thunderbird's, with the rest of the models getting one in 1965.
But alternators could be special ordered before 1963.
When one is dealing with the Gov't, who knows what the heck is goiing on? This was the case in the past, it's the case today...and will be the case tomorrow!
