New guy says hello....
Great site you have here. I'm probably going to be stopping by occasionally since I purchased a '72 F-350 today. It has a 10' Galion dump bed on it and it only has 63K miles. It's in really good shape for its age and pretty much everything still works on it, from the windshield washers to all the gauges to the AM radio. I'm going to try to bring back the shine to the original paintjob, clean up the interior, and replace the cherry bomb glass pack on it with a real muffler. Here's what it looks like. I got it for $3K....
Wow - if not for the grille - it's nearly identical to the 68 we used to use for landscaping. Great truck - hauled loads! Easy on the gravel, though you don't want to overload it & break something! And I wouldn't just half their delivery price - Try $85 - a little cheaper, but you'll need to $$ when the first repair bill comes in. And not sure @ where you are, but check into insurance & registration rates if you intend to haul for hire...
It's a good looking rig. like said above don't cut the rates in half, it is already a cut throat business and you will find out soon enough why they charge 100 bucks. that rate is likely for larger trucks and there is a niche in the ebusiness for smaller truck loads but try to keep your rates up.
I'm in the Louisville, KY area. I would be hauling mainly for relatives and friends so I wouldn't try to get rich off of them.
I'm going to paint the outside of the dump bed so what kind of paint should I use? Also, I'd like to coat the inside of the bed with something strong and tough similar to a spray on bedliner. Can I buy that stuff someplace? If so, what's it called and where can I find it? Thanks....
I would just brush it on so I'll go with the Rustoleum. Do you know what shade of blue this is called? If I can't find something close I'll probably go with black. I think I can bring the paint on the cab back to life with a good washing and heavy coat of wax. Thanks for the info. There's probably going to be a lot more questions coming in the future....
The paint on the cab is chaulked but it doesn't look that bad. Before you wax it though you might try some fine rubbing compound. A less expensive way is to scrub it with a light kitchen cleanser, rinse it a couple times then wax it after it's had a chance to dry. I always used Bon Ami brand but others will work too. This is an old used car lot trick that really works for white or light pastel colors.
Be safe.
Thanks for the tips. I worked for a roofing company for 5 years and drove a liftbed/dump truck and that was a lot bigger than this one and I never managed to tip it over. I remember another company that tipped over a liftbed full of gravel at a new car dealer and destroyed two brand new Buicks a few years ago....
