I inherited my dad's guns when he died. One of them is a revolver that had been in a house fire. I can't tell you anything more about it, because it is ib storage at the moment. I think it might me a 32 or 38 with a 4 or 6" barrel. I'm thinking from recollection that it has a 4" barrel. From outwards appearance the barrel looked straight.
Anyways, I'm just wondering do you guys think it would be safe to fire?
I just had an idea. Put a small light behind the barrel and see if the light shows where I aim the gun. What's your thoughts on this?
Anything else I should be worried about?
being a 32 or 38 I would just shoot it, if it were a higher powered caliber or if your are really concerned about it , take it to a gunsmith & have it checked out
Give us more info on the make and model no. and caliber if possible.........have a gunsmith check it out anyway. Was it burnt down to nothing but frame? Grips gone?
Well I'd have to dig through a 12 by 40 storage unit to find it.
Yes it was burnt to just the frame, no grips.
I'm thinking the gun is from sometime in the sixties. i know the house burnt down before I was born.
My uncles house burnt down. He had a fireproof safe with about 20 guns in it. The guns survived but had extensive heat damage and the insurance company at first refused to cover the guns since they were in the safe. He told the adjuster "OK, but you fire each gun first to make sure they're safe." Suddenly he had all new guns, and a new safe.
First and foremost, I'm sorry to hear that your Dad passed away.
Second, DO NOT shoot that handgun until a QUALIFIED gunsmith says it's safe to do so!
In fact, I'd send it back to the manufacturer (if they still exist) and have them look it over.
You can send the firearm directly to them (you don't have to go through an FFL holder), but, I'd send it by UPS Overnight. (Horror stories abound about people sending firearms through FedEx! Don't use them!!)
The manufacturer can send the arm directly back to you, when they return it.
I've seen one instance, where a .38 Special S&W revolver was in a house fire, then shot.
Now, the flames didn't destroy the revolver, but, the revolver 'got hot' for a while.
The revolver (literally) came apart (violently) when fired.
You never know how much damage a firearm has endured in a fire.
If the stocks of your revolver were burned badly or completely, I'll wager that the steel has suffered some damage.
I would NOT shoot that handgun until someone QUALIFIED said it was safe to do so.
I'm with Keith. Have it checked out, no matter what.
There's no telling what kind of damage may have been done by the fire with the naked eye. Heat can have very nasty effects on the properties of metals.
Whether it would be safe from a catastrophic failure is one question, and would depend on the metallurgy of the frame, cylinder, and barrel. But it really is pointless, because the gun is useless and possibly would not fire anyway. The springs will have lost their temper, hard components like the sear and bolt will have become soft, even the firing pin is likely to deform after only a few shots. Best to just keep it for it's sentimental value, and figure out a way to permanently disable it so that future owners don't try something stupid.
Very sorry for the loss of your Dad...and the fire.
I'm of the opinion that a gunsmith can give you guidance. Fires can cause metal fatigue, warping, stress...
I'd be of the mindset, as Keith suggested, cooked grips, really concern me.
Many GS's can bench test remotely..don't have to hold it to fire it.
Get a reputable GS to test it. It's worth the $100 test if it's salvageable, or worth $1,000,000 if not, and is a potential exploder maiming or killing you and/or those near you.
