PLEASE HELP: C6 intermediate servo acc valve spring broken
Old Mar 13, 2010 | 10:06 AM
Ekkehard's Avatar
Ekkehard
Question PLEASE HELP: C6 intermediate servo acc valve spring broken
I have pulled the C6 transmission on my 78 F150 for overhaul, and just found the bigger (outer) intermediate servo accumulator valve spring broken into pieces.
I have searched sources in Sweden, without luck so far, and we soon need to put the transmission back together and into the truck again since it occupies workshop space, and I need the truck.
Now: can I drive the truck with just the smaller (inner) spring, or do I need both springs? If I decide to go with just the smaller spring, what will happen to the transmission?
Any help is appreciated.
Thx /Ekkehard
Old Mar 13, 2010 | 10:09 AM
Ekkehard's Avatar
Ekkehard
Workshop manual says "Intermediate servo acc valve not used in police, taxi, fleet", -do I need the valve and the two springs at all or can I run the transmission simply without?
Thx /Ekkehard
Old Mar 13, 2010 | 10:36 AM
jk080's Avatar
jk080
Transmission Rebuilder
You have to use the valve but you can just leave the springs out if you want.
Old Mar 13, 2010 | 10:41 AM
Ekkehard's Avatar
Ekkehard
jk080, -thanks for the fast reply. If I leave both springs out, what will that do to shifting? Or better to put one spring back in?
Should also mention that the transmission had a 2-3 flare, most likely due to the worn-out clutch plates we found during the overhaul...
Thx /Ekkehard
Old Mar 13, 2010 | 07:13 PM
jk080's Avatar
jk080
The 1-2 shift may be a bit firm, you can put the one spring thats not broken back in, it will help reduce the shock going into 2nd. I have left them out before and I didnt think the shift was uncomfortable.
Yea I agree worn clutches in the direct drum will cause a 2-3 flare.
Old Mar 14, 2010 | 01:10 AM
Ekkehard's Avatar
Ekkehard
Thx for the advice !!
/Ekkehard
96_F250_Deezal
May 22, 2018 10:39 AM
bjmayberry2
WTB - Parts & other
Jan 15, 2016 02:23 PM
Rusty_S
Oct 12, 2015 12:19 PM
96_F250_Deezal
Apr 6, 2015 10:02 PM
easygoin4
1983 - 2012 Ranger & B-Series
Apr 5, 2012 08:17 AM
