Best head gasket
Old Mar 12, 2010 | 11:22 PM
F-250 restorer's Avatar
F-250 restorer
Best head gasket
I am porting my head and need to know what is the best head gasket to use.
Thanks.
Old Mar 13, 2010 | 06:27 AM
dustybumpers's Avatar
dustybumpers
stick with the felpro head gasket, I have never had one fail. the mr gasket exhaust/intake has worked best for me with the headers, I forget the #. [ I'm old]
Old Mar 13, 2010 | 07:18 PM
F-250 restorer
I notice Felpro has 3 head gaskets for the 4.9. They have a $20, a 'severe duty' gasket for $30, and the hp gasket with pre flattened steel compression seal, and steel core laminate construction for $58.99.
On my first engine I used the cheapest of the gaskets, and when I pulled it apart two mechanics noticed that gasket was nearing failure between a couple of the cylinders. This time around I am using the ARP studs, and the hp gasket.
Any comments are appreciated.
Old Mar 13, 2010 | 07:39 PM
dustybumpers
I would go with the steel core laminate one, for the motor you have built
Old Mar 14, 2010 | 07:42 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Sounds like a plan. No sense cheaping on a gasket.
