Yea I know you can I just want to know if anybody has don this or tried it. everything measures the same and it bolted up. I just am not sure to stick it in the truck or not.
Milt Check Cheaperjeepers gallery. He lists part numbers that he used whe he did his zf conversion. 1986 Ford F250 4x4 - T-19 to ZF-5 Swap I tried to cross them to NAPA numbers when I did my conversion but no luck.
Yea I'll use the dual mass before I spend anything, I just got to looking and everything fits like this. I was just wandering if anybody had done it. lol I might just take rupes advice there, then I'll at least know, lol
I'm running a 6.9 smf with 6.9 smf pressure plate with zf5 clutch disk in my 7.3, and it works great. I put that in when I did my e4od to zf5 swap. I have been running it for 9 months with no issues, and was wayyy cheaper then the luk smf setup. I even used all used parts, but next month I am putting in new clutch disk, pressure plate, etc from autozone. I also found out from cheepers jeepers old thread that it would work.
