79 column wiring
Old Mar 12, 2010 | 09:13 AM
bmuhlbach's Avatar
bmuhlbach
79 column wiring
I'm putting a 79 Auto column in my 68 f100 found a wire diagram for the blinkers and horn still need to figure out the Emergency flasher wiring.Now my question is about the neutral safety switch to the trans and wiring to the old plug that would have been on the column.Any one have a wire diagram for the plug on the 68 and the switch on the trans?
Old Mar 17, 2010 | 12:46 AM
bmuhlbach's Avatar
bmuhlbach
There is 4 wires on the switch I'm thinking 1- should be hot which one? 2-one to start in park 3 reverse lights 4 to start in neutral
Old Mar 17, 2010 | 04:41 AM
jowilker's Avatar
jowilker
Where is that ALL knowing dummy when you need him????
John
Old Mar 21, 2010 | 08:59 PM
bmuhlbach's Avatar
bmuhlbach
Will got most of the wires connected but there is a white with red stripe that needs to connect to emergency flashers I think the old one in the glove box has 4 wires any done the conversion or know how to wire up the flashers to work with the switch in the column?
