What to expect
Old Mar 11, 2010 | 11:49 PM
truckerboy's Avatar
truckerboy
What to expect
Hi,
I am looking into a 89 F250 with the 7.3 IDI, and I am wooundering what are some know problems with this motor?
Does this motor pull good? I dont want to repeate what happened to my chevy, in which case i overloaded it (24000 on a trailer hooked to a k2500), let out the clutch and bent the crank. Id hope that FORD motors are better built than chevy and dodge.
Also, will the new low sulfer diesel run ok in this motor??
Old Mar 11, 2010 | 11:58 PM
Marianna2003's Avatar
Marianna2003
The IH engine in these fords are near bullet proof. 24,000# on a trailer will not make for a quick trip, but you will get there.
You would do well to add some type of additional lubricity to the ULSF. These engines were designed before ULSF was even thought of.
wreckinball's Avatar
wreckinball
main known problem is the Cavitation issues. Thinner cylinder walls so ensure the previous owner was aware of this and kept SCA's or DCA in the coolant. That way it can be prevented.
The motor can pull, that is for sure. It cant perform miracles though and 24000 on any truck below an F950, haha, is way over the limit including your chevy. Dont expect this truck to pull 24000 please, Holy Smokes. Now that being said i pulled a 5000 pound stock trailer with about 8000 pounds in the trailer up a 25% incline driveway like it was nothing. They can do well but if you want that kind of strength, 24000, you need something turboed and made by caterpillar! hahaha just kidding
You will have to make sure and keep lubricity additives in the fuel or it will lead to premature failure. Our trucks were made for regular diesel. They dont even like low sulfur. Howes, Power Service, Stanadyne, Racor all make good additives. Some can be bought at walmart, other at a diesel specialist or diesel parts retailer.
Best luck and let us know more on the truck when you know, all the details!!
Old Mar 12, 2010 | 12:01 AM
starmilt's Avatar
starmilt
LMAO They will run fine on the fuel, but a little fuel conditioner is a good thing.
If you have been bending cranks when you let out on the clutch, I don't know how it will hold up. I can tell you the ford cranks are pretty stought steel.
Old Mar 12, 2010 | 12:03 AM
wreckinball
Damn bro, the best towing capacity i am seeing anywhere for a k2500 is 10000. I would say you overestimated a touch? maybe? just curious!
Old Mar 12, 2010 | 12:06 AM
truckerboy's Avatar
truckerboy
I learned that $2500 lesson then. Aperantly the axle and trans were torque locked from the weight of the load. The motor was turning and the trans wouldnt, thus causing the crank to trrn at the front, but warp at the flywheel.
BTW, dads 86 F250 (300, T18) pulled it without a prob, although he had to start in Lo every time. (Built Ford Tough)
Old Mar 12, 2010 | 12:10 AM
truckerboy's Avatar
truckerboy
Hey, i was just the driver. See concreate and steel statues are the family business. Dad and the supplier loaded it up, and i had to drive home. Long story short dads F350 (300, T18) pulled it fine, allbeit at about 40 mph, starting in Lo every time and going 77 to 81 (usually go US 52 to US 221, but thats sucicide at 25000 lbs in any truck)
Old Mar 14, 2010 | 12:44 AM
idahodisco's Avatar
idahodisco
I did a search and nothing so I have to ask because I would like to get a idea of my trucks life!
How many miles and what you have had to fix?
I will start 91 F250 idi 175,000 miles Replaced transmissin at 140,000 miles replaced water pump and had to replace radiator 170,000!
I need to fix Transfercase rear seal + front diff seal + Cruse control.
Old Mar 14, 2010 | 12:55 AM
truckerboy's Avatar
truckerboy
i aint got it yet, but its got 255,000 and needs nothing mechanical. The seat is all to pieces, but still drivable.
89 F250, 7.3 IDI, 4x4, hd auto w/overdrive.
Old Mar 14, 2010 | 01:00 AM
idahodisco's Avatar
idahodisco
Sorry I thought I was starting a new post! I have a new post now!
Old Mar 14, 2010 | 01:03 AM
truckerboy's Avatar
truckerboy
thanks man.
skytop
Aug 1, 2012 11:00 AM
no limit
1997 - 2003 F150
62
Jan 28, 2009 01:00 PM
twp
1997 - 2003 F150
Jan 11, 2008 01:25 PM
nickmobile67
General Automotive Discussion
18
Feb 4, 2007 11:50 AM
christop43
16
Oct 23, 2003 05:34 PM
