need help with 352 4v
Old Mar 11, 2010 | 09:56 PM
turtle13b's Avatar
turtle13b
hi all need some help with a 66 352 4v stock in a galaxie500 with a crus o matic im looken for torqu not hp the only thing is i dont have alot of cash so any help would be welcomed oh and the old car runs really well itll one wheel peel all day long
Old Mar 11, 2010 | 10:59 PM
85e150's Avatar
85e150
If it will spin the tires with ease now, what will you do with more torque?
If it's in '66 spec, it was rated at 352 lb/ft at 2800 rpm. (gross, probably still over 300 net).
FE Series Engine Specification Chart
So, what tricks would be cheap? Headers I suppose, as FE motors have pretty poor exhaust manifolds.
A different intake & carb, you can find people fighting about what's best in other threads here, and you'll find many recommend the stocker. If you got it in aluminum, that would be 50 lbs off the front end....
Cam, but then that starts to run money.
Electronic ignition, later Ford or aftermarket. A small help, mostly in reduced fiddling and more consistent running.
Standard tune and carb rebuild if needed.
You have factory dual exhaust, right?
390 or 428 crank and a few other select parts will get you a 380/390/400/410 depending on stock or .050 overbore....
http://www.woodyg.com/fairlane/finfo/fecidcombo.html
Other strokers available....
How much do you want to spend?
Old Mar 11, 2010 | 11:12 PM
turtle13b's Avatar
turtle13b
i would rather not stroke it if any thing i was thinken about a petronex igntor some long tube headers and ive been told a rv or camper stile cam and a holloy 700cfm carb. ive got a set of 360 truck heads wonder if they would make more power
Old Mar 11, 2010 | 11:14 PM
LindenBruce's Avatar
LindenBruce
Add Traction Lock and gearing with some of the above mentioned mods. Will keep both tires planted and give a better launch depending on what ratio you select. Those 9" rears are easy as heck to upgrade. Find a good used Traction Lock unit, install new clutches, new ring and pinion with bearings and out the door you go smoking both rear tires. Bruce
Old Mar 11, 2010 | 11:21 PM
85e150's Avatar
85e150
You probably don't need to go to a 700 cfm carb, 600 is big enough and will run cleaner on the low end methinks.
The ignition and headers would be a big help.
The 360 truck heads are probably D2TE heads--probably very similar to the heads you have, but with hardened seats.
Old Mar 11, 2010 | 11:22 PM
turtle13b's Avatar
turtle13b
what would be a good gear to use ill want to drive the car on the weekends and stuff through town and stuff no long trips but when i nail it i want it to go
Old Mar 11, 2010 | 11:30 PM
LindenBruce
Well, your factory gears are probably in the low 3:00's. Mustang drag pack gears are like 4:10 or 4:30 to 1. So, pick something in between for cruising and play. Say 3.73:1 or 3.80:1 ratio. Bruce
Old Mar 11, 2010 | 11:38 PM
85e150's Avatar
85e150
That car had 15" wheels stock, what tire are you running? Our '66 wagon was 3.0 fwiw....
dwestcessna
Dec 8, 2020 01:37 PM
67Grandy
17
Aug 5, 2013 08:18 AM
89ford73
21
Jun 19, 2011 07:45 PM
Bill W
Apr 2, 2007 06:15 PM
caseyatthebat1
Feb 2, 2002 12:19 AM
