Dont neglect your brakes like I did!
So I knew I needed to change my brake pads but I went way too long without changing them. Eventually I started hearing a grinding/rubbing sound coming from the brakes, I thought there was something caught in the caliper or something like that but when I pulled off the caliper what I found was MUCH worse..
The pads were completely worn down, like there was no pad material left; just the metal backing which was rubbing on (and clamping on) the rotor grinding it down!
How can I tell whether my rotors are still good enough just to be turned instead of replaced?
I know its not funny, but ive seen worse. My brother had an old Dodge Colt, he said his brakes starting squealing (and my brother is one of those people that if its out of sight, its out of mind) so we pulled his brakes, He had NO pad left, i mean no pad or backing metal, he wore it down till the entire pad assembly was gone and he was relying on the caliper piston cup grinding on the rotor to stop him, i know thats a major major major saftey hazard, but it was sort of funny when we pulled it all apart and thats what we found.
Thats pretty impressive. I don't think you could get a shop to turn those, but if you have the "hook up" you could have someone turn them and see if they are still in spec when done. Although I really doubt they will be. But since you need new everything you might as well switch to ceramic pads, I did and it has eliminated a lot of the dust from the regular pads. Good Luck.
there is no way that those can be turned and still remain in spec....just replace em and keep your eye on them more in the future. BTW, how did they feel? Any noises/ pulsing? Just curious because I have never seen brakes that bad. Glad you are getting that issue taken care of tho.
~jstnromero
~jstnromero
~jstnromero
~jstnromero
The only thing I did notice was a soft grinding noise and a tiny bit of pulsing when almost stopped. Needless to say I was extremely surprised and a little spooked when I first saw the pads!
whether you think its a major safety hazard or not....it was....metal on metal doesn't stop for anything compared to brake pads on metal....plus.....you were a minor metal fracture away from not stopping at all......your probably really lucky that these trucks have a major rear brake bias and those were about all that stopped you...
I hope you wont find what I did!
By the way, are you still looking for an OEM cat-back? I have one that Ive been trying to get rid of. message me!
