voltage test
Old Mar 11, 2010 | 12:56 PM
wickedklown83's Avatar
wickedklown83
voltage test
hi guys trying to run a voltage test to see where my craw in the system is, thought it was the voltage regulator, but with a new one it is drawing just as much if not more. any other ideas what it could be? also on my voltmeter in the DCA i have 4 settings, which one should i use, i have 200u, 2000u, 20m, and 200m, i ran the test on the 20m the last few tests, is this correct? ( old reading were about 2.80, new reading are about 3.60- 3.70)
Old Mar 11, 2010 | 07:32 PM
wickedklown83
bump back to first page, anyone have any ideas for this problem??
Old Mar 11, 2010 | 07:43 PM
deeznuts822's Avatar
deeznuts822
I always used 20 m.
Old Mar 11, 2010 | 09:57 PM
Conanski's Avatar
Conanski
What voltage are you getting across the battery with the engine off and with it running?
Old Mar 11, 2010 | 10:51 PM
wickedklown83
ok as dumb as it may sound, how do i test it across the battery, ive only tested for draw by hooking the voltmeter in line with the negative post to negative terminal, and like ive said in another post, im more of a mechanical than an electrical type of person
