Speedometer caliberation
Old Mar 11, 2010 | 12:35 PM
allen03's Avatar
allen03
O.K. I know my speedometer does not match my GPS due to tire size is there a way to adjust it to right with out having a tuner?
Old Mar 11, 2010 | 12:54 PM
PaysonPSD's Avatar
PaysonPSD
You can adjust for tire size using AE.
Changing tire size using AE - Originally posted by Ron's power stroke Thanks Ron
After the pcm logs on you will get the vehicle selection box. When it opens go to the bottom where it says System.
It should already say enhanced power train Click the drop down arrow and change it to anti lock brake then click on ok.
After the truck connects click on the test on board system tab. Click the drop down tab next to the initiate button and select
tire size.
When that opens there will be a left and right arrow on the far right next to the initiate button. Click the right arrow
to get a bigger tire.
Old Mar 11, 2010 | 01:16 PM
03_PSD's Avatar
03_PSD
I need to try this with AE. I'm running 35's now.
Old Mar 11, 2010 | 01:21 PM
allen03's Avatar
allen03
What's AE? ? Sorry nee to all this
Old Mar 11, 2010 | 01:43 PM
PaysonPSD's Avatar
PaysonPSD
Allen,
AE is AutoEniginuity scan tool. AE Home Page LINK.
Available through Riffraff Diesel LINK
Anyone with AE in the Pompano Beach area?
Edit : One more post Allen and you can start using PMs(Private Messages).
Old Mar 11, 2010 | 03:10 PM
CSIPSD's Avatar
CSIPSD
Yup... You can ajust to 40's with AE... and do as many rigs as you want.
Old Mar 11, 2010 | 03:25 PM
allen03's Avatar
allen03
am i correct in thinking i can change the programing on my truck and my wifes truck without buying another AE? all i will loose from buying this over the others is switch on the fly?
Old Mar 11, 2010 | 03:38 PM
CSIPSD's Avatar
CSIPSD
No tuner on the market can ajust for tire size on a 7.3... You dont get a tuner for ajusting tire size.
You can get a programer or chip for the power, shifting and such...
AE is a tool, something you can run every test a ford shop could do and more.
It also allows you to ajust for tire size, on anyone's rig you plug into... Very nice!
Old Mar 11, 2010 | 05:49 PM
ron's power stroke's Avatar
ron's power stroke
tire size.
i was looking for that a week ago to help some one out..i couldnt help cause i couldnt find it....thanks for posting it..now it is saved...
Old Mar 11, 2010 | 05:56 PM
PaysonPSD's Avatar
PaysonPSD
Glad I could help.
Old Mar 11, 2010 | 09:23 PM
F250_'s Avatar
F250_
It's also on the RHN site, Ron.
Old Mar 11, 2010 | 09:30 PM
PaysonPSD's Avatar
PaysonPSD
Good to know Pete. I gotta get over there and look around more often.
Old Mar 11, 2010 | 11:46 PM
twags6's Avatar
twags6
Is there a limit to the number of times you can change it?
Old Mar 12, 2010 | 08:13 AM
F250_'s Avatar
F250_
No limit to number of changes.
Old Mar 12, 2010 | 09:31 AM
ron's power stroke
i must be blind...i still dont see it
but i do have it now..thanks Pete..
