Lubing upper Ball Joint?
Old Mar 10, 2010 | 01:25 PM
BostonX73's Avatar
BostonX73
While working on the hubs and front yesterday I noticed the upper ball joints have zerks in them. I tried to get my grease gun in there but didn't have enough room to get at it from the top, and the hose was too thick to slide up through the Ujoint and hit it.
swung by the parts store this morning and their suggestion was one of the needle injectors to pierce the boot and fill it that way.
has anyone found an easier way? I did a search and found nothing good expect that you might be able to swap for a 90 degree fitting, if it's short enough not to hit the Ujoint.
Thanks
Old Mar 10, 2010 | 02:46 PM
Airslot's Avatar
Airslot
Don;t have an image of it in my mind, but it your turn the wheels in either direction, will it improve access?
Old Mar 10, 2010 | 03:54 PM
Hollywood703's Avatar
Hollywood703
never seen one with a straight zerk on the upper. I would also suggest cranking it to the side and moving it forward in small incriments. Not sure what other options are possible as I also am having a hard time visualizing the area at my desk.
Old Mar 10, 2010 | 04:10 PM
1975StroppeBaja's Avatar
1975StroppeBaja
oooh... don't pierce the boot! Then water can get in there and start wreaking havoc.
The Moogs I put on mine come with a 90deg fittings and a plugs. Some folks have ground the 90deg fitting slightly to clear the u-joint. I've always just swapped out the plug for the 90deg fitting, then put the plug back.
So, the 90deg fitting should do the trick. I wouldn't pierce the boot though!
Old Mar 10, 2010 | 04:53 PM
cbradford's Avatar
cbradford
I just leave the 90* fitting in and ground down to make clearance works just fine.
Old Mar 10, 2010 | 05:36 PM
BostonX73's Avatar
BostonX73
Yeah, not sure if the upper is stock or not. Don't think turning the wheel changes thing - but I'll check tomorrow.
Can I remove the zerk in there and swap in a 90 while it's all in the truck?
I was hesitant about piercing it.
Old Mar 10, 2010 | 06:52 PM
cbradford's Avatar
cbradford
I don't believe any OEM were greaseable and yes you should be able to change zerk fitting with out any disassembly.
Old Mar 10, 2010 | 07:35 PM
njstevens's Avatar
njstevens
you should be able to change it . i use this older way older as it was my grandfathers. Im guessing 70's grease gun that is meant to use only small tubes . The hose on it is flexible and skinny works well for that and my garden tractor
Old Mar 10, 2010 | 07:50 PM
bigbugman's Avatar
bigbugman
i put the 90 degree on the bottom and the straight on the upper and then use a straight fitting adapter to lube the top zerk available at tsc
Tight Tolerance Grease Coupler - 3952688 | Tractor Supply Company
Old Mar 10, 2010 | 09:23 PM
BostonX73's Avatar
BostonX73
thanks bigbug - I'll see if I can find one of those adapters. looks like harborfright has them for less than $2.
if not may try to swap in a 90 degree zerk.
I've got two grease guns, a new, large one, and an older smaller one - both with a flex hose on the end and neither would get up there.
labman1014
Aug 8, 2012 10:23 AM
Dieseldan7.3
15
Dec 9, 2005 07:39 PM
bassaway
1983 - 2012 Ranger & B-Series
May 23, 2005 11:00 AM
89 bronco II
Oct 6, 2004 08:30 PM
