shifting hard
Old Mar 10, 2010 | 12:06 AM
smelser509's Avatar
smelser509
shifting hard
hey guys just picked up a 93 f-150 5.0 auto its shifting really hard im assuming i have e40d.. door label has a T in the trans spot.. ok already checked the VSS, speedometer is not jumping, and i noticed today that there is a wire hanging from under the glove box unpluged and marked PSOM.. I also do not have a mlps on the trans just a throttle cable.. does anyone know about the wire hanging and do i have a e40d my pan has 14 bolts thanks
Old Mar 10, 2010 | 07:26 AM
redneckin2010's Avatar
redneckin2010
i do believe you have a aod, the e40d was a 20 bolt pan and not but in 1/2 ton trucks untill a later time. im not very knowledgeable on the aod so i cant help you with the shifting.
ryan
Old Mar 10, 2010 | 08:30 AM
Bayer-Z28's Avatar
Bayer-Z28
Check your TV cable to see if it is adjusted correctly. If that throttle valve is opened up all the way it increases the line pressure and either hangs the gears open longer or shifts hard. (IIRC) The E4Od has an electric solenoid to control the line pressue (IIRC.) Either that or there is some gunk in the valve body hanging up a valve and upping the pressure.
