Sponsored by: Real Truck
changing ring and pinion gears
Old Mar 9, 2010 | 09:16 PM
Rescue1950's Avatar
Rescue1950
Question changing ring and pinion gears
I have a 2002 f250 super duty 5.4 gas engine I am changing my differential gears from 3.73 to 4.10. I tow a 7000lb trailer and I was told if I change the gears I would notice a big difference. Can anyone tell me any of the torque specs and anything else I would need to know before I start this project.
Old Mar 9, 2010 | 09:28 PM
Pinky Demon's Avatar
Pinky Demon
To be honest, I would go higher than a 4.10. That isn't far off from 3.73 at all. The difference will be minimal. Try 4.30 or 4.55 if you want to really get extreme.
BTW, Randy's Ring and Pinion is where you want to order from. Extremely knowledgeable people, courteous, prompt, on the ball, with good tax free prices. (If they are not in your state.)
Old Mar 10, 2010 | 08:20 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You need more than "torque specs" to replace a ring and pinion. You might want to see how much it would cost to get a shop to do it for you.
Old Mar 10, 2010 | 08:59 AM
cowboyup1988's Avatar
cowboyup1988
i hear a lot of people say order from randy's ring and pinion but i found their prices a bit high. i ordered my gears from Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale they knew their stuff and fast shipping. same gears as randys's for less. not trying to bash anyone though... 4.55 would be too much for stock tire height IMO. I'm putting 4.88 in my lifted f250 with 35's because i'm planning on going to a bigger tire. hope this helps
Old Mar 10, 2010 | 12:05 PM
Furian's Avatar
Furian
You Keep What You Kill
Not bashing anyone... but I prefer BroncoGraveYard.com as well.
http://broncograveyard.com/
Old Mar 10, 2010 | 09:48 PM
DAVE67FD's Avatar
DAVE67FD
IMO being a "02" truck with most likely high mileage you may be better off with the master rebuild kits. If getting into teardown the kit would be your better choice. As Krewat mentioned if your not close to an expert or have done it more than a few times you may consider having them done. Will become rather costly but you have a better piece of mind.
Old Mar 11, 2010 | 12:28 AM
Furian's Avatar
Furian
His profile indicates that he has between 50K-75K miles on the truck...
Old Mar 11, 2010 | 01:21 AM
redford's Avatar
redford
The change to 4.10 gears is very significant. You'll notice it.
Everything being equal, the 4.10 gearing will increase your torque at the rear axle roughly 10%. 4.33 gears will get you roughly 16% more torque than the 3.73 gears. But, everything isn't equal.
Besides the additional torque multiplication, the gearing also raise the engine RPM for the given speed, thus gaining more power (within reason).
How much? Using the factory ratings and my truck as an example, with the 3.73 gears Ford says I can tow up to 9200 pounds. Throw in 4.10s from the factory (and no other change) and Ford bump that rating up to 11,000 pounds. That's an increase of a little over 19% towing capacity from a simple gear change.
800screws
Nov 2, 2015 12:33 PM
Daleksandrovich
Mar 22, 2014 09:37 AM
klr650goldwing
Modular V10 (6.8l)
Oct 23, 2013 06:47 PM
1992FordF150Custom
22
Aug 5, 2013 06:11 PM
85300
21
Jun 6, 2010 12:25 PM
