HIGH IDLE HELP!!
Old Mar 9, 2010 | 05:04 PM
Nikki13's Avatar
Nikki13
Unhappy HIGH IDLE HELP!!
Alright, so i have a 1999 Ranger XLT manual. Ive done a lot of work on it and so far its not paying off. I found out that my EGR was leaking causing a high idle, so i decided to change that along with all the wires and all the spark plugs. For about 2 days my idle seemed to be down and it wasnt as "rough". Then i started driving on the highway and my check engine light comes on , its a code i saw once before , and it was there even before changing my EGR, Its P-0133 Bank 1 sensor 1 oxygen sensor slow responce. When i checked the pattern of the oxygen sensor on an oscilliscope, it was fluctuating as it should. So i really dont understand, What could be causing a high idle, at about 900 RPMS, poor fuel economy, and that oxygen sensor to come on! HELP
Old Mar 21, 2010 | 01:34 AM
blueFTR's Avatar
blueFTR
dude i got a 2000 ranger XLT manual. i am having a problem with a high idle too. there is no check engine light on though. Im having a tough time finding the problem. if i can figure it out i will let you know. also with the O2 sensors some times they get some carbin build up on them they can mess up. you probably checked that though.
Old Mar 21, 2010 | 09:49 AM
Nikki13's Avatar
Nikki13
Yeah i did check the 02, turns out it was insufficient switching, so im changing that. But im so lucky, that i have to remove my Y pipe to get the o2 off cuz its rusted and stripped. And nothing will get it out. As for the high idle, its still there, and a lil bit of a shake at idle too, i checked for vaccum leaks and everything. Still no clue.
Duckman77
May 13, 2013 08:37 PM
Brandon50394
Aerostar
Sep 18, 2012 01:43 PM
casper1999
1983 - 2012 Ranger & B-Series
Oct 4, 2010 07:53 PM
rcknrbn
Sep 9, 2008 08:47 AM
headshrink
18
Sep 16, 2006 05:07 PM
