tire question?
Old Mar 9, 2010 | 04:24 PM
|WYG|SS's Avatar
|WYG|SS
tire question?
i got a 93 f150 4.9l 5spd 4x4 with 31x10.5x15 bfg AT's and the tires are starting to do this /-\ does that mean a tie rod is going bad? when i got the tires 1 year ago i had an alignment done and my machanic said i needed something done where he has to pop the upper ball joint off and replace a shim or something that would cost $600 per side and i think i just needed the driverrs side done now i will probably have to do both. i have read you can do this yourself is it hard?
Old Mar 9, 2010 | 04:32 PM
Conanski's Avatar
Conanski
Your front springs are sagged, replace them.
Old Mar 9, 2010 | 04:36 PM
|WYG|SS's Avatar
|WYG|SS
what would be a good brand to get cause i got 88 f250 leafs in the back without the lift block and the back end sits up like 2 inches higher in the back. i want to leavel the front and possibly even put the lift blocks back in sometime in the future. their was one someone had told me was a good brand i think it started with an M.
