The compass is backwards
Old May 10, 2002 | 09:35 AM
djexpi's Avatar
djexpi
I have a 97 E.B. and the compass has never really worked correctly it has a mind of its own i heard that you can hold down the reset button and drive in a circle. I would really appreciate any information. Thankyou!
Old May 10, 2002 | 10:56 AM
Boxter's Avatar
Boxter
Think I might be able to help. I have a 2001 XLT (no trip computer). There are 2 ways to set the compass.
1: Can set it by Zones (You will need your manual for this as your location is not listed in your profile). Turn you ignition to the on position. Press and hold the select button until VAR appears in the display. The display should show the current Zone number. Press the Select control until the correct Zone appears. The display will flash, and then go to normal operation.
2: Compass calibration adjustment. (Do this away from steel structures and high voltage lines). Start the truck.Press and hold the SELECT control until CAL appears in the display (about 8 secs). Drive the veh. slowly (less than 3 mph) in circle until CAL indicator turns off in 2-3 circles. Done.
Hope this helps.
Old May 10, 2002 | 02:33 PM
djexpi's Avatar
djexpi
Thankyou BOXTER for the information i will try it and see the outcome!
Old May 13, 2002 | 12:00 AM
djexpi's Avatar
djexpi
[updated:LAST EDITED ON 13-May-02 AT 01:04 AM (EST)]I tried calibrating my compass just like you said but nothing happened. I didnt get the screen so i decided to hold both buttons down to activate the reset mode, then turned on the vehicle. I found all these different areas on the screen but i didn't find a way to reset these areas? i am going to the dealer in a few days, but if any comment please replay to the message thankyou
Old May 13, 2002 | 09:23 AM
Boxter's Avatar
Boxter
Do you have an EB, or XLT? Does your truck have the Trip computer. There are different directions for the unit with the trip computer.
Boxter
Old May 13, 2002 | 09:29 AM
sfc2001's Avatar
sfc2001
I had the same problem on my 99 Expy, could not get the compass to calibrate whether I followed the correct procedure or not. All the time I spent on the damned thing, I ended up just replacing it (about 100 bucks, I think...) It comes off in about five minutes, it's the device behind your rear-view mirror...
My recommendation: just get a new one. Fixed me right up.
Old May 14, 2002 | 12:43 AM
djexpi's Avatar
djexpi
I went to the dealer,Boxter, and they fixed it right up like brand new. They said it was the zones like you said. Thanks for the help.
Old May 14, 2002 | 10:26 AM
Boxter's Avatar
Boxter
Glad I could help!
Boxter
Old May 14, 2002 | 12:02 PM
gkateley's Avatar
gkateley
05F250DSL
Oct 20, 2013 08:17 PM
eric777
Apr 30, 2007 04:21 PM
