New here, few questions
Old Mar 9, 2010 | 12:33 AM
Brian Abington's Avatar
Brian Abington
Hey guys,
I am new here. I lurked for about a day or so and decided to sign up.
This past week I bought a 94 F-150 XLT.
It is the extended cab, short bed, has the 5.8L 4X4 automatic.
Has just over 152,000 miles and the only thing it needs is some rust repair. other wise its great!
My question is where can I find what options the truck has? I read some were online that these 4X4's had some gear options but I have no idea what they would be or how to determine if that info is even correct.
It also has a unique paint setup. It is white, with a medium grey stripe across the bottom. Kind of how the eddie bauers had the tan across the bottom. I looked through the thread of all the pictures and have not seen another one like this, so I am wondering if there is something special about this paint style.
Thanks,
Brian.
Old Mar 9, 2010 | 01:06 AM
TexasGuy001's Avatar
TexasGuy001
Welcome! The paint scheme is fairly common. Many of the XL trucks had it as well. There is a VIN decoder on this site, but I can't find it right now.
Old Mar 9, 2010 | 01:08 AM
Brian Abington
hmmm, I thought mine was special because I had only seen single color, two tone and the wacky paint styles.
Old Mar 9, 2010 | 02:34 AM
ichabod40's Avatar
ichabod40
The vin decoder on this site: VIN Number Decoder offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
As far as your gears, there should be a tag on the rear axle, that will have the gear ratio as well as the serial number stamped on it.
Old Mar 9, 2010 | 08:05 AM
BigBlueOx's Avatar
BigBlueOx
You can also look on the drivers door post and look for the axle code. Once you find it, post it here and someone can direct you to a code chart or just tell you what it is.
Old Mar 9, 2010 | 11:25 AM
Brian Abington
thanks guys,
Seems that this site will be my best source for information!
Old Mar 9, 2010 | 02:20 PM
Brian Abington
Ok I looked at the door jamb sticker.
here is what it says:
Trans E
Axel H9B
Springs M4I
Old Mar 9, 2010 | 02:31 PM
Lazy K's Avatar
Lazy K
Ford Door Sticker Decoder .: Articles Here is a link to the door sticker decoder.
Old Mar 9, 2010 | 02:42 PM
Brian Abington
so it says that i have the 3.55 limited slip.
Is that both front and rear or just the rear?
Old Mar 9, 2010 | 02:58 PM
Lazy K's Avatar
Lazy K
Only the rear will be limited slip. However the front will be the same ratio.
If you do a fluid change on the front and read diffs make sure you use either the gear oil with the LS additive in it or get the additive seperately and put it in with the straight gear oil in the rear diff.
Old Mar 9, 2010 | 03:26 PM
Brian Abington
good to know. Since I was planing on changing the fluid this spring.
Brian794x4
Offroad & 4x4
Mar 6, 2007 10:51 PM
blp848
Jan 16, 2006 11:51 PM
Brian794x4
Aug 12, 2005 10:03 PM
umdstang
2004 - 2008 F150
Mar 5, 2005 04:04 PM
brianj
Paint & Bodywork
19
Sep 15, 2003 02:04 PM
