HELP, window/radio glitch?
Old Mar 8, 2010 | 06:00 AM
Baciagaloop's Avatar
Baciagaloop
Hi guys, Anyone have any ideas on this;
2005 F350 super duty 6.0
When I start my truck, sometimes the radio and the door windows don't work for a while. Could be 40 seconds, could be 10 min. Everything else works, you can even load and unload a cd, but that is it, radio won't go on, power windows don't work, and map lights I believe.
Any thoughts would be appreciated.
Old Mar 8, 2010 | 08:49 AM
firemanpat29's Avatar
firemanpat29
this has been discussed before. its seems to me the common link is that all the things that work on the time delay circuit after you turn the truck off but before you open the door are the items affected. I would think a loose or bad relay to that circuit. I have had this issue maybe 4 times in my 07, with 70,000 miles. I havent bothered to find it, cause it always only does it once then is fine for many months, talk about hard to trouble shoot!!!!! there are some threads on here about it but none that I recall coming to a cure.
Old Mar 8, 2010 | 09:23 AM
Baciagaloop
Thank you very much
