78/79 power steering
Old Mar 7, 2010 | 07:03 PM
BigCountry77's Avatar
BigCountry77
My 78 f 250 4x4 is on a 72-77 frame. it has the control valve power steering setup pn it. my contril valve leaks and needs rebuilt. i would like to switch in the integral power steering. What year models could i get the integral setup off of. i no they used that setup in the 80's, just dont know if it would fit. i just want to know what i need to go lookin for in the junk yard. i know this is a popular swap so if anybody has any advise or pics, that would be great.
Old Mar 7, 2010 | 09:45 PM
starmilt's Avatar
starmilt
None of them is what you would call a fit, there is some fab work involved, some is easier than others. DO a search on steering and you will find several different options.
Old Mar 8, 2010 | 09:46 AM
mark a.'s Avatar
mark a.
Most people use a '77.5-'79 f-250 4x4 box & there is some fab work involved. Frame crossmember has to be notched, thats the worst part of it though.
Old Mar 8, 2010 | 05:41 PM
BigCountry77
like what kind of fab work?
Old Mar 11, 2010 | 09:10 PM
radar457's Avatar
radar457
go to www.fordification.com and look around in there I found the diagram and step by step info there once but cant tell you just where..
Old Mar 12, 2010 | 12:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BigCountry77
My 78 f 250 4x4 is on a 72 -77 frame. it has the control valve Power Assist power steering setup pn it.
It's not a 1972 frame if it has P/S. P/S was not available until 1973 in 4WD's.
my control valve leaks and needs rebuilt. i would like to switch in the integral power steering. What year models could i get the integral setup off of. i no they used that setup in the 80's, just dont know if it would fit. i just want to know what i need to go lookin for in the junk yard. i know this is a popular swap so if anybody has any advise or pics, that would be great.
Why not just reseal the control valve you have now? There are kits available, but...there are two different control valves.
All 1973's, 1974 F250 4WD's before serial number T80,001 used GARRISON Power Assist P/S.
1974's from serial number T80,001, 1975/77 F250 4WD's (High Boys) used BENDIX Power Assist P/S.
The parts for the Garrison system do not interchange with the Bendix system.
Old Mar 12, 2010 | 01:20 PM
montana_highboy's Avatar
montana_highboy
http://www.stangerssite.com/TruckCVparts.html
