Help with C6
Old Mar 7, 2010 | 05:34 PM
2004460's Avatar
2004460
Exclamation Help with C6
i just got a 1977 f150 with a 460 the kick is missing i want to hook it up my ? is the kickdown lever on the trans is spring load down so dose that mean for the kick down to work it needs to be pulled up by the kickdow rod to ingauge? and are kickdown rods somthin i could get off another motor trans combo? and last thing the vac modulator is not hooked up idk if i got the right modulator in it is there more than one type? to hook up do you just run steel line with ruber on the ends to the manifold ? this was someones project that i took over so i wana get it right you know thanks
Old Mar 8, 2010 | 12:46 PM
Lazy K's Avatar
Lazy K
You are right about how the kickdown works. You should be able to get a rod at a junk yard but it needs to be the right length so, I would think, you would need one off another 460 or maybe a diesel. Another way to go is to use a cable. If you don`t mind manually downshifting for passing you could just leave it disconnected.
The vacuum is important, it controls the shift points. You need the vacuum pipe from the modulator connected to full manifold vacuum (same as brake booster). The stock setup is as you describe, rubber pipe from modulator to steel pipe running up the back of the engine and then a rubber pipe to manifold vacuum.
there are different modulators (different color stripe on them) but I wouldn`t worry about that.
Hopefully other opinions will follow.
Old Mar 8, 2010 | 01:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ7A187A .. Kickdown Rod / Fits: 1975/77 F100/350 460 C6 / Obsolete
No Ford Dealer or obsolete parts vendor has any.
D5TZ7A377A .. Vacuum Modulator Valve (Motorcraft TM30) / (1) Black or Brown Stripe / Single Area Diaphram.
Fits: 1973/79 F100/350 C6 351M/360/390/400/460 except for high altitude applications (5,000 ft. or higher).
D8TZ7A377A .. Vacuum Modulator Valve-Altitude Compensating (Motorcraft TM49) / Single Area Diaphram
Fits: 1973/79 F100/350 460 C6.
jetrinka
Jan 27, 2015 07:49 PM
ford truck oldboy460
Feb 26, 2009 06:36 PM
Feb 23, 2009 01:32 PM
fordguy76
Nov 1, 2006 10:43 PM
cbwarrior
Mar 18, 2002 08:59 AM
