1978 - 1996 Big Bronco
conversion constant
Old Jan 22, 2003 | 12:41 PM
diggum's Avatar
diggum
Question conversion constant
Does any one know what the conversion constant should be on 35 12.50 15's I now know how to change it but just need the number it should be changed to. I know 31 10.50's is 9.18 but that is still to small. so just need for mine.
thanks
Old Jan 22, 2003 | 05:58 PM
AlM's Avatar
AlM
conversion constant
yo,
look here:
https://www.ford-trucks.com/articles...peedorecal.php
Old Jan 22, 2003 | 07:34 PM
steve83's Avatar
steve83
conversion constant
You need to go to the Tire Rack and look up your exact tire to get the mfr's spec for revs per mile. What kind of truck do you have (year/model/rear axle)? F-150s & Broncos have 108-tooth tone rings, and bigger trucks usually have 120 teeth. You'll need to know both before using the CC forumla which is:
ConversionConstant = RevsPerMile x ToneRingTeeth / 8000
Check here for more info.
Old Jan 23, 2003 | 08:35 AM
diggum's Avatar
diggum
conversion constant
perfect that was a big help. but jsut to double check I have a 1996 sport Bronco. The tires are 35 12.50 15's BFG T/A KO so by my calculation i come up with 8.0865 so do i set it to 8.09 then. I would assume so.
Thanks guys
raderrods
Aug 9, 2011 11:03 AM
Duderoy
Feb 9, 2003 04:24 PM
302FROGMAN
Jan 9, 2003 10:36 PM
kk
16
Oct 16, 2002 09:37 AM
