Aerostar Ford Aerostar
Battery Light
Old Mar 15, 2010 | 05:30 PM
  #31
99f350sd's Avatar
99f350sd
You've got it figured out..Buy a cheap caliper compressor tool. Lube caliper pins.
Old Mar 15, 2010 | 09:34 PM
  #32
mediaman67's Avatar
mediaman67
Hi,
I have a craftsman one that works well and like 3 sizes of C Clamps too :-) - I even have the caliper grease that I bought for the job...
Question - should, as part of the job, I get like the brake hardware kit? has like new little metal parts, etc?
Can I re-use the Caliper bolts? on my 89, and I think any of that era Ford truck that was 2wd, they used a set of pins that are like square pegs that tap into the grove, and they tell you to never reuse those, but they are rubber, so that is why I'm sure.
Thanks
Old Mar 15, 2010 | 10:02 PM
  #33
99f350sd's Avatar
99f350sd
If they are the rubber hammer in pins I would get new one's. Hardware kit for the rears if you do them..I don't know what the front brakes look like on that vehicle.
Dick
Old Mar 16, 2010 | 11:23 AM
  #34
mediaman67's Avatar
mediaman67
I just had the rears done with all new ebrake hardware redone, new cables, the works, so those I'm leaving :-)
Just the front brakes... just didn't know what was a good idea to replace, or reuse...
Thanks
Old Mar 16, 2010 | 11:25 AM
  #35
99f350sd's Avatar
99f350sd
High mileage replace..
Old Mar 16, 2010 | 12:12 PM
  #36
mediaman67's Avatar
mediaman67
The book says if it's 4wd, they would be bolts looks like - I think Ford only used the tap in pins on the 2wd models, but I could be wrong here...
Thanks
Old Mar 18, 2010 | 04:38 PM
  #37
Aeroman59's Avatar
Aeroman59
Buy the hardware kit & a tub of synthetic brake grease. Replace the pads & if the rotors are scored too much consider getting new ones (any hammer on the brake pedal ?). If the caliper pins are good you can take back the hardware kit for a refund. Don't forget to fit the anti-rattle springs when installing the new pads.
Aeroman.
Old Mar 18, 2010 | 04:42 PM
  #38
mediaman67's Avatar
mediaman67
The rotors are drilled and slotted, so I was thinking of just having them turned - maybe actually getting another set, and then always having one good to go...
Do Explorers go through brakes? I think I only have about 15K on this brake job, and they are squeaking all the time now... still stop, but surprises me
consol
May 7, 2010 07:28 AM
mediaman67
23
Mar 22, 2010 05:28 PM
bozomedic
Aerostar
Dec 27, 2005 04:45 PM
Operator
1983 - 2012 Ranger & B-Series
Nov 21, 2004 07:08 AM
