1978 - 1996 Big Bronco
i need help!
Old Jan 22, 2003 | 11:29 AM
skitz's Avatar
skitz
i need help!
i have an 83 bronco! i need to know what transmission, transfer case, gears, rear end, front end, and original tire size. if someone could help me out that would be great. oh..........and if i have lockers or not.
Old Jan 22, 2003 | 12:14 PM
Kemicalburns's Avatar
Kemicalburns
i need help!
best thing to do is check your door jam for a sticker that will give you some of the information you need. other thing to do i climb under there and look, there should be tags on most everything you are needing. the tranny shouldnt be to hard. how many gears do you have. if its a three speed its probably a c6, if it has drive then its a aod. you need to give us info on what things look like now because with out seeing it in person its a little difficult. you can also get a haynes/chilton manuel which will help identify alot as well.
good luck
Old Jan 22, 2003 | 01:11 PM
greystreak92's Avatar
greystreak92
i need help!
Pull the VIN from the dashboard and Ford will tell anything you want to know about your truck. 1-800-392-3673
Old Jan 22, 2003 | 02:58 PM
sideout2's Avatar
sideout2
i need help!
you should have a C6 tranny(if auto) T18(if manual), D44TTB front, 8.8 rear Most likely 3.55 ratio. Need the tag to know if it is limited slip or not. The tag will say somthing liel 3 L 55 or 3 55
L = Limited slip.
