1978 - 1996 Big Bronco
dash fix
Old Jan 21, 2003 | 10:25 PM
bronco cam's Avatar
bronco cam
dash fix
I have a 96 bronco. it has a small crack in the dash. Does anyone know if the piece on the dash above the glovebox can be removed and replaced. It looks like it could be removed. Has anyone out there done this. I am not talkinng about the trim piece that says xlt. I am talking about the piece above that . It looks like it is seperate from the main dash. Or does anyone know of another way to fix it
thanks
Old Jan 21, 2003 | 11:11 PM
83Steve's Avatar
83Steve
dash fix
The soft pad is separate, but the hard plastic is one piece from the top of the dash down to the bottom below the glove box. Which one is cracked? I have a dash I'd like to sell. Look here & PM or e-mail me if you're interested.
http://www.webphotos.com/list_photos...&smi=2&a=95012
Old Jan 22, 2003 | 09:06 AM
anollmann's Avatar
anollmann
dash fix
Someone on ebay was selling a brand new dash cap for late broncos... Was the whole replacement pachage for like $60 or so. Not sure if it was OEM... I will see if I can find it again.
Old Jan 22, 2003 | 12:33 PM
Lookinfurfun's Avatar
Lookinfurfun
dash fix
Check out http://www.coverlaymfg.com/
Old Jan 22, 2003 | 05:25 PM
bronco cam's Avatar
bronco cam
dash fix
It is the soft cap above the molding that is cracked. Did you say that it can be removed and replaced?
Thanks
Old Jan 22, 2003 | 07:31 PM
steve83's Avatar
steve83
dash fix
Yes, but the fasteners aren't easy to get to. If you use a mirror, you might be able to see them thru the glovebox.
