Sponsored by: Innova
2001 expedition nav system install
Old Mar 6, 2010 | 05:41 PM
ronzer's Avatar
ronzer
Working on installing a indash nav system in my 2001 expedition need to find the speed input sensor and Reverse gear signal input wires. Anyone have any pictures or info on these?
Thanks
Ben
Old Mar 6, 2010 | 06:24 PM
ReAX's Avatar
ReAX
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|yellow |+ |ignition harness |
| STARTER|red/lt. blue |+ |ignition harness |
| IGNITION|lt green/purple |+ |ignition harness |
| ACCESSORY|brown *1 |+ |ignition harness |
| SECOND ACCESSORY|black/green |+ |ignition harness |
| POWER LOCK|pink/yellow |*8 |driver's kick panel |
| POWER UNLOCK|pink/lt green *9 |*8 |driver's kick panel |
| LOCK MOTOR|pink/black | |driver's kick panel |
| UNLOCK MOTOR|red/orange | |driver's kick panel |
| DISARM DEFEAT|pink/orange *2 | |driver's kick panel |
| PARKING LIGHTS +|wht/blk or brown | |headlight switch or DKP |
| PARKING LIGHTS -|white/purple | |*3 | | HEADLIGHTS|red/yellow |+ |headlight switch |
| DOOR TRIGGER|*4 |- |*4 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|white/purple |- |driver's kick panel | | HOOD PIN|tan/lt.green |- |driver's kick panel |
| FCTRY ALARM ARM|arms on lock *5 | | | |FCTRY ALRM DISARM|dk. green/purple |- |driver's kick panel |
| TACHOMETER|tan/yellow | |PCM *6 |
| SPEED SENSE|gray/black |8 |PCM *6 |
| BRAKE WIRE|lt green |+ |driver's kick, brake switch |
| HORN TRIGGER|yellow/lt. green |- |steering column |
| WIPERS|wht & dk.blu/org *7 |+ |wiper motor or relay |
| LF WINDOW UP/DN|wht/blk - red |A |at motor in dr door |
| RF WINDOW UP/DN|wht/yel - tan/lt.blu|A |sw dr door or dr kick |
| LR WINDOW UP/DN|yel/lt.blu - gry/org|A |sw dr door or dr kick |
| RR WINDOW UP/DN|yel/blk - red/blk |A |sw dr door or dr kick |
| RADIO 12V|lt green/purple |+ |at radio |
| RADIO GROUND|black |- |at radio |
| RADIO SWITCH|yellow/black |+ |at radio |
| RADIO ILLUMINATE|red/black |+ |at radio |
| LF SPEAKER|org/lt grn-lt blu/wh| |at radio |
| RF SPEAKER|wht/lt grn - grn/org| |at radio |
| LR SPEAKER|tan/yel - gry/lt blu| |at radio |
| RR SPEAKER|org/red - brn/pnk | |at radio |
Notes: NOTE: Some models of this vehicle are equipped with PATS (Passive Anti Theft System). Use DEI module 555U to over-ride during remote start. *1 Two brown wires at switch, both have to be powered for remote start. *2 You may also use the pink/green power unlock wire. *3 On early production vehicles it is in the driver kick panel, in the harness to the rear of the vehicle. On late production vehicles it is behind the glove box at the central security module. *4 In the drivers door harness find yellow/black for the drivers door. In the drivers kick panel find lt. green/yellow for the drivers rear door. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All four wires are negative trigger and must be diode isolated together. Refer to directfax document #1076 for wiring information. *5 Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm. *6 The PCM is located at the top of the firewall towards the passenger side, the tan/yellow tach wire is also found at the back of the instrument cluster. Can also use any tan/stripe at the coil pack. *7 Also found yellow/white (-) at the firewall connector. *8 On models with keyless entry the doorlocks are negative trigger. Without keyless entry they are 5wi reverse polarity. *9 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1093.
I think the VSS is blk/pnk, I can't remember the reverse wire.
Old Mar 6, 2010 | 07:13 PM
ronzer's Avatar
ronzer
what is vss? is that the speed sense?
Old Mar 6, 2010 | 07:55 PM
ReAX's Avatar
ReAX
Vehicle Speed Sensor (VSS).
Old Mar 7, 2010 | 10:39 AM
ronzer's Avatar
ronzer
ok thats why im confused. In the above post it says speed sense is gray/black then you said VSS is black/pink.
Anyone have any info on the reverse wire?
Thanks
Ben
Old Mar 7, 2010 | 11:18 AM
ReAX's Avatar
ReAX
Maybe it was the reverse that was blk/pnk. It's in this forum somewhere, I remember a couple of discussions about it.
Eric123
65
Jun 3, 2008 11:42 AM
rtilley
May 19, 2008 11:24 AM
marktaylor69
Apr 8, 2007 01:59 PM
