Which heads are better?
Old Mar 6, 2010 | 01:24 PM
daves54's Avatar
daves54
i have two sets one is a set of C6EA-U and the other set is D2TE AA. Which set is better and why? One set is still on the block so I can't see the valves.
Old Mar 6, 2010 | 02:49 PM
LindenBruce's Avatar
LindenBruce
Well, the D2TE AA are 1972 truck style heads with induction hardened exhaust seats for unleaded fuels. You will see a lot less seat recession with these heads. I was thinking of building a set for my 69 Mach 1, but decided to stay with my C8OE-N heads. I'm not sure how the ports and valves compare between either set. Do a google search on each casting number and it will take you to a site that will break them down by specs. Bruce
Old Mar 6, 2010 | 03:41 PM
daves54's Avatar
daves54
Thanks for the info
Old Mar 6, 2010 | 03:54 PM
Bear 45/70's Avatar
Bear 45/70
They are pretty much the same except for the hardened seats in the D2 heads. However you can upgrade the C6 heads with hardened valve seats while the heads are in the shop for a valve job.
Old Mar 23, 2010 | 09:56 AM
LedheadELH's Avatar
LedheadELH
I guess I need some clarification. I thought the C6AE heads are the older style, vary large open D-shaped combustion chamber, w/ taller intake ports too?? Or do you mean the same because they are all just factory cast heads, w/ not a GREAT deal of differences?
davester250
Aug 5, 2015 10:30 PM
jayloveland
Jun 6, 2015 10:46 AM
Stevaroo01
Apr 19, 2015 08:10 PM
1968Mustang
Computer Chips & Tuners
Jul 25, 2006 09:35 AM
DrFord
Jun 20, 2001 04:45 PM
