Sponsored by: Real Truck
Need Help. Replacing Cat With Straight Pipe
Old Mar 6, 2010 | 08:22 AM
Cluney93's Avatar
Cluney93
Im looking to get rid of my cat today because its holding back the real tone of my super 44 muffler. I live in Canada so Im aloud to do so. I was wondering do it have to be a special type of pipe to weld in its place? I have my old stock exhaust system lying around and would I be able to chop the old tailpipe up and put it in the cats place?
Old Mar 6, 2010 | 09:03 AM
ontariofarmer's Avatar
ontariofarmer
I don't know where in Canada you are but, you can't do it here. It wouldn't pass the e-test.
Old Mar 6, 2010 | 10:04 AM
Franko72's Avatar
Franko72
Molon Labe
The easiest way to do it, is to just take the cat off and knock out the ceramic honeycomb with a hammer and a rod of some sort, and bolt it back on.
That is unless the connections are all rusted up, then I may be easier just to cut it off and weld or clamp in a pipe.
Make sure you dont have any inspections first. If its just a visual insp, then I suggest the first method.
Good luck
