4.9L 300 Engine replacement.
Old Mar 6, 2010 | 07:35 AM
79 F100 Stepside's Avatar
79 F100 Stepside
I recently (last month) bought a re-manufactured long block and took on a task I had not done in many years. I spent about a week doing it but it is running good. I threw all that emissions stuff into a box and plugged all the vacuum leaks. I would like to buy a new carb and get rid of the block between the carb and the intake manifold. Any suggestions?
Old Mar 6, 2010 | 07:59 AM
4x4 Bart's Avatar
4x4 Bart
You will need an older carb to be jetted correct and you will need to do some distributor work or its going to ping at partial throttle.
It may be easier to put the emissions back in place.
Old Mar 6, 2010 | 08:04 AM
4x4 Bart's Avatar
4x4 Bart
If you got the cash an Offy dual plane manifold and a four barrel would be the ultimate choice.
Old Mar 6, 2010 | 09:16 AM
79 F100 Stepside
This sounds like the ticket.
