Bump the pump
Old Mar 5, 2010 | 11:35 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Bump the pump
Alright, im sure this has been covered 100 times over, and i know i read one at one point but the search button has let me down. Exactly which cover is the fuel screw under? I see the two bolt one in front of the pump, but i thought i recalled someone saying you need a mirror to see in it, maybe its just me, but i can get to it fine if thats it, havent pulled it open yet. For those that remember, as i think i have the HA model im planning on going 1 flat to see what i get from it till my pyro gets shipped and then ill play with it from there. The search did show me something about a torque screw, and i just wanted to clarify, that is only on the factory turbo IP's correct?
Old Mar 6, 2010 | 10:26 AM
tabascom16's Avatar
tabascom16
Behind the triangular cover on the passenger side. Probably will take a little mirror to see in the hole while someone rotates the crank until it comes into view.
Old Mar 6, 2010 | 10:35 AM
starmilt's Avatar
starmilt
If you are getting any black smoke now I would wait on the pyro before playing with it.
Old Mar 7, 2010 | 01:12 PM
hairyboxnoogle
no smoke whatsoever except if you pop the throttle at idle or try and lug it to death and even then you can barely see it. Haha my 400 smoked more.
Old Mar 7, 2010 | 02:37 PM
rodneywar's Avatar
rodneywar
I have the same symptoms as above would truning the pump up a flat make it a bit better? i do not want to roll coal at all just a bit more fuel!!! sorry about the
Old Mar 7, 2010 | 07:58 PM
rupejosh's Avatar
rupejosh
yup but i would still buy some cheap insurance(pyro)
Old Mar 7, 2010 | 08:48 PM
rodneywar's Avatar
rodneywar
so whats the max you can go with out melting the pistons?
Old Mar 7, 2010 | 09:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Hypereutectic aluminum will start to melt at 1250 degrees.
You do have piston oil squirters that cool the pistons, but they spray on the bottom.
Going above 1250 does not mean catastrophic instant engine failure, but it does mean you are putting a lot of heat into the engine oil and are in dangerous territory.
If you lug a diesel, you may freak when you see how hot a stock engine EGT can get that is not blowing black smoke.
