Frame differnece between 80's and 90's?
Old Mar 5, 2010 | 08:33 PM
Ford Trucks 11's Avatar
Ford Trucks 11
Is there a difference between the frames on the 87-90 and a 90-96 F-250? Also is there a difference between the F-150 and the F-250 from behind the cab back? I would like to know if I could cut a 92 F-150's frame right behind the cab and use use it to replace one on a 87 F-250.
Old Mar 5, 2010 | 09:25 PM
Diesel_Brad's Avatar
Diesel_Brad
80-91 is basickly the same . The 92-97 are the same up untill the front frame horns
Old Mar 6, 2010 | 06:01 AM
EPNCSU2006's Avatar
EPNCSU2006
I don't know about the rest of the frame, but the transmission cross member and support brackets from a '95 F150 fit the mounting holes in my '87 frame.
Old Mar 6, 2010 | 06:30 AM
NavyMIDN08's Avatar
NavyMIDN08
the early 80's (i think 80-82) had what was called the swiss cheese frame. its full of holes. my father has that frame on his f-250 plow truck and has never had a problem, other guys avoid them or plate the frames.
just another difference
Old Mar 6, 2010 | 10:12 PM
Ford Trucks 11
Ok, so I just found a '96 F-250. I want to make sure I can cut it behind the cab and swap out the rear with my '87 F-250. Thanks for the help.
Old Mar 7, 2010 | 10:18 AM
NavyMIDN08's Avatar
NavyMIDN08
wait what?!?!? you're going to cut the frame section to replace it with a different rear frame section?!?! i just have to ask why. is the 96 damaged? if its just rust or the axle, they will bolt right on. cutting the frame is a HUGE job. it needs to be z'd in, properly aligned, and you'll always have a weak spot in the frame, and you'll be dealing with heat seep problems, leading to potentially brittle portions. assuming they're both long beds, all the parts should interchange.
what is the rationale for cutting the frame?
Old Mar 7, 2010 | 10:27 AM
DIYiT's Avatar
DIYiT
I agree with NavyMIDN08, why cut the frame? Can you do a cabswap from your 87 to the 96?
Jwhit85
23
Oct 4, 2023 04:28 PM
jason90f150
Aug 28, 2016 08:33 PM
abosely
Nov 23, 2015 06:45 AM
Pele
18
Aug 30, 2007 12:03 PM
