Qusetion regarding moisture?
Old Jan 22, 2003 | 01:03 AM
biglevi71's Avatar
biglevi71
I have dual exhaust from the cat back with no mufflers. When the stock muffler was there, moisture used to drain out in a small hole in the bottom of the moisture. I am wandering if there should be a place for moisture to drain out of the new set up. Pipe was put in place of the stock muffler, then to a Y pipe, and then rear dual chrome tips out the back. Will this hurt my engine? and what should I do if anything to get moisture out. When I start the truck there is always moisture coming out then. Is that enough or should there be hole in the pipe to let it drain. My dad noticed this, and now I am starting to wander. Moisture probably isn't good if it is just sitting there. Thanks for any info. Levi
Old Jan 22, 2003 | 08:34 PM
1984_355w's Avatar
1984_355w
As long as it gets good and warm it will all evaporate out of there. Should be fine.
