Can closed knuckle, dana 44's be improved upon; namely disks, or other?
Just curious,
I tried the search, but couldn't find it. I know these are the BA**ard of all front axles according to some, but I wanted to know what can be done to improve the 3/4 ton low pinion dana 44; from disk adaptation to strength improvements, other than tossing them to the garbage can??????
They're a pretty stout axle but if you want to upgrade the easiest and cheapest route is to just swap in a 77.5-79 disc brake/high pinion axle, there's a disc brake conversion kit out there but it's ridiculously expensive... 4x4 Front Differential Disc Brake Kits
there's also parts still available for these axles but they too are expensive and becoming very scarce... QUAD 4 x4_
I'm almost 100% certain they can be but don't quote me on that because i haven't personally converted one over, i know their numbers are fewer but i've never had any difficulty finding the 3/4 ton 8 lug, leaf sprung HP D44's in junk yards, it may take a little looking but they are out there.
Any more questions??
countrydriven
07-24-2017 05:31 PM
Rollingscrapmetal
22
11-21-2016 04:10 AM
David85
24
01-02-2010 01:53 AM
