muffler delete 7.3L
Old Mar 4, 2010 | 10:35 PM
merlinx's Avatar
merlinx
muffler delete 7.3L
Has anyone installed a muffler delete by expandit? I saw one for $64.99 and thought it was a steal. On a stroke of course.
Old Mar 4, 2010 | 11:07 PM
Stewart_H's Avatar
Stewart_H
What size?
ITP Diesel has 30" pipes for $38 bucks. 36" pipes for $42 bucks.
4" Single & Dual Muffler Delete Pipes
Stewart
Old Jan 14, 2011 | 05:43 AM
SC-Ex's Avatar
SC-Ex
The "ITP Diesel" link's muffler delete pipes are all 4", and are available in various lengths and aluminized or stainless steel.
Stock exhaust is 3.5", so these will only work with after-market systems.
Old Jan 14, 2011 | 02:52 PM
Stewart_H's Avatar
Stewart_H
I'm not sure how that adds to a 10 month old thread, but ok.
Just curious, but why did you bring stock versus aftermarket into the mix? Were you thinking the OP was wanting to add the muffler delete to a stock setup?
I ask because that't not something I'd thought about, and had assumed he already had an aftermarket setup, so good point!
Stewart
Old Jan 14, 2011 | 03:05 PM
SC-Ex's Avatar
SC-Ex
No point at all. I'm trying to add one to my stock exhaust.
The post prior to that was for adding the muffler-delete-pipe to an aftermarket 4" setup.
I think I've found one for the stock 3.5, but they don't have info/pix online.
Anyone know of one? Can';t seem to find it in stainless ...
Old Jan 14, 2011 | 05:36 PM
Stewart_H's Avatar
Stewart_H
Ah, ok. I can stop chastising myself then for assuming.
I had assumed the same thing, but when I read your post, I started thinking otherwise!
Maybe a local exhaust shop can make one for you?
Stewart
Old Jan 15, 2011 | 08:41 AM
SC-Ex's Avatar
SC-Ex
Perhaps.
The one I found is made by "EXPANDIT" and is only 30" long, which is the same length as the muffler. It has the ends expanded to allow the ipe to insert in, but that won;t work because it will be too short once I cut the same length muffler out of the stock system.
I'll post whatever I find.
Would love some input form anyone who has done this to a stock system.
Oddly enough, a couple of diesel sites offer a muffler delete pipe from ExpandIt, but state that it won't fit Excursions for some reason.
Old Mar 16, 2011 | 03:57 PM
Studawg's Avatar
Studawg
Thread Ender
Hey SC-Ex, I was very interested in a previous thread that you started about the stock muffler delete, when it was removed. I am trying to add a 3.5" Aero Turbine muffler to my stock exhaust and trying to figure out how to do it. The inlets and outlets are offset on the stock exhaust and are straight thru on the new muffler. The rear hanger is welded to the muffler, which will be removed, and the front hanger is on a section that will have to be turned to counter the offset of the rear section of pipe. I dont have a welder, so I cant weld on a new hanger, and I really dont want to go to an exhaust shop. I guess I can always use a coat hanger to hang it with!!
Old Mar 16, 2011 | 03:59 PM
Studawg's Avatar
Studawg
Thread Ender
Perhaps.
I think that the rear most section of pipe, from the muffler back, is different on an Excursion than it is on a Super Duty. I think it may have to do with the location of the gas tank.
Old Mar 16, 2011 | 04:13 PM
SC-Ex's Avatar
SC-Ex
Stud,
Yes, Ex and F250/350 are different.
Never did do it. Think I'll go with 3.5" Stainless Flex instead anyway ...
Stainless Steel Exhaust Flex 3.5" ID
Old Mar 16, 2011 | 04:24 PM
Studawg's Avatar
Studawg
Thread Ender
Thanks, that might be the stuff I need. Call me Stu.
Old Mar 16, 2011 | 04:36 PM
SC-Ex's Avatar
SC-Ex
Gotcha - thot the Stud was catchy ... ;-)
Old Mar 16, 2011 | 04:41 PM
Studawg's Avatar
Studawg
Thread Ender
Do you know if I can get this stuff locally? My muffler is supposed to be coming in on the fedex truck any minute and I really want to put this thing on tonight!
Old Mar 16, 2011 | 04:44 PM
hhcobra's Avatar
hhcobra
Good find SC-Ex. Been looking for some. Will that slip over the pipes?
Old Mar 16, 2011 | 04:52 PM
Studawg's Avatar
Studawg
Thread Ender
I think it will. By my measurements, the stock exhaust is 3.5" OD, and if this stuff is 3.5" ID, it should slip over with a little persuasion.
BTW, we have ourselves a little South Carolina pow-wow here dont we?
