Coolant Filter Brackets ...
Old 03-04-2010, 08:51 PM
98SurplusExpy's Avatar
98SurplusExpy
98SurplusExpy is offline
I'm going to pop on one of the Dieselsite coolant filter set-up's here soon. Looking at the bracket sold with the kit, I can already imagine it being "fun" to change.
I've seached around and found folk that have fabricated brackets that come off the alternator ... these seem much easier to access.
Can anybody post pics of your custom brackets? Here are some that I found:
Type 1:
Type 2:
Old 03-04-2010, 10:53 PM
rocky1074's Avatar
rocky1074
rocky1074 is offline
I have the dieselsite coolant kit installed it's really not bad changing the filter. I do recommend adding the valves from dieselsite or pick them up at Lowes or Home Depot so that you can close them while changing the filter. Makes it a cleaner job with no loss on coolant.
Old 03-04-2010, 11:01 PM
Jakebrake's Avatar
Jakebrake
Jakebrake is offline
< Samantha...my Co-Pilot
I have probably changed my filter at least a half dozen times and have not had a problem yet. Get the ball valves on the inlet and outlet and it will be a cleaner change experience.
Old 03-05-2010, 06:08 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,421 Likes on 2,106 Posts
I will be installing a coolant filter from Dieselsite soon on my friends truck so I will have to see what they offer for a bracket. I did mine from scratch before any kits were offered and I still like my mounting bracket so far.... Not to bust anyone but that third picture down is a nightmare.....I used Aeroquip push on fittings, no butt ugly clamps lurking to scale back your hand and actually laid it out with direction in mind. I never added ball valves because it doesn't hardly drain any amount of fluid while installing a new filter.
Old 03-05-2010, 06:20 AM
harley boy's Avatar
harley boy
harley boy is offline
i don't have one yet but all
the setup that i seen look
esay to change filters
Old 03-05-2010, 07:46 AM
zhilton's Avatar
zhilton
zhilton is offline
The only issue I have is snaking the filter in/out around the a/c, CAC and coolant lines. You can get them out...it just the filter takes up the available space.
After looking at Maxium4X4 photo...gosh, I wish I had connectors like that. What does it look like were the coolant goes back into the degas bottle?
Old 03-05-2010, 09:00 AM
Maxium4x4's Avatar
Maxium4x4
I just used a small T fitting back into the degas line.
Old 03-05-2010, 09:22 AM
69cj's Avatar
69cj
69cj is offline
I've had no problems at all changing this or any other filter on the 6.0.
Old 03-05-2010, 09:41 AM
zhilton's Avatar
zhilton
zhilton is offline
Don't guess you've got photos of the T fitting? The one I've got from DieselSite uses those ugly screw-hose clamps.
Old 03-05-2010, 11:47 AM
Maxium4x4's Avatar
Maxium4x4
No I don't have, I just used Aeroquip fittings which are push on. When the Dieselsite kit arrives for my friend we may change the fittings, have not seen it yet. I just preferred the fittings over the old clamp on for a cleaner install, nothing wrong with the old way of doing things it still gets the job done.
98SurplusExpy
1999 to 2016 Super Duty
09-12-2012 12:33 PM
98SurplusExpy
31
05-25-2012 08:19 AM
07xpyebel
17
04-14-2012 07:07 AM
98SurplusExpy
08-05-2009 08:54 AM
98SurplusExpy
07-15-2009 10:45 AM
Quick Reply: Coolant Filter Brackets ...
