Differentials?????
Old Mar 4, 2010 | 08:39 PM
ke6zmy's Avatar
ke6zmy
Differentials?????
In the video at this address;
YouTube - Ford Excursion OFF Road-The Best
you can see, starting at 2:49 -as well as other points-, the front driver side tire spinning and the passenger side tire static.
It is disappointing to see.
What type of front differential does the Ex's have? Manufacturer?
Old Mar 4, 2010 | 08:47 PM
TYZ78F150's Avatar
TYZ78F150
Well the front diffs don't have the LS like the rears. maybe thats what it is?
Old Mar 4, 2010 | 09:29 PM
EXv10's Avatar
EXv10
Dana 50 in front, Ford Sterling rear. Most are non L-Slip
Old Mar 5, 2010 | 04:01 AM
CanadianSmokie's Avatar
CanadianSmokie
You can pick up a Lock Rite locker under $400 for the Dana 50 and install it yourself....
Old Mar 5, 2010 | 02:15 PM
X-Hibition's Avatar
X-Hibition
European plates, Russian accents, 6-8 inches of snow, and that was the best they could do? It's not the differentials, it's the driver.
This is why Communism failed.
Old Mar 6, 2010 | 07:00 AM
Hollywood703's Avatar
Hollywood703
I would disagree this is all driver.....Their availability to aftermarket parts is very limited there....Its likely besides maybe suspension and tires, that that truck is quite stock. Its also deceptive to see someone coming up a hill, a true video should have the camera set level to see true grade. As it appears he doesnt have limited slip even which would limit his ability to traverse uneven slippery terrrain.
Old Mar 7, 2010 | 01:31 AM
howler4x4's Avatar
howler4x4
That is normal for any part-time 4x4. Standard diffs send power to the wheel with the least traction.
The limited slip Track-Lock was an option for the Excursions rear axle, but not offered for the front Dana 50.
Here's everything you ever wanted to know about traction aides:
diffs.htm
fixnair
Dec 10, 2012 04:59 AM
rob29956
Aug 6, 2010 02:30 PM
motopsyko32
16
Oct 25, 2008 09:46 AM
88EB
1978 - 1996 Big Bronco
Oct 9, 2001 07:05 AM
