Fuel Pump?
Old Mar 4, 2010 | 04:07 PM
AWB2010's Avatar
AWB2010
Fuel Pump?
My truck stopped running about a week ago, I thought that it had gelled up due to being so cold. Anyhow I replaced the filters and now I am not getting any fuel to the top filter housing. I pulled the power to the pump and have 12v there but still no fuel. Does this mean I need to change the pump or is there something else that would not allow the pump to run?
Old Mar 4, 2010 | 04:31 PM
harley boy's Avatar
harley boy
make sure you a fuel going thru the first filter then check the pump
Old Mar 4, 2010 | 07:49 PM
ljutic ss's Avatar
ljutic ss
With the key on you should hear the pump running. When you changed the primary filter, was it leaking fuel the whole time you changing filters?
Old Mar 6, 2010 | 04:32 PM
AWB2010's Avatar
AWB2010
No, only about a quart of fuel came out when I changed the filters. I can not hear any noise when turning the key on. I do have voltage at the wire harness but no noise from the pump.
Old Mar 7, 2010 | 06:12 AM
harley boy's Avatar
harley boy
you need a new fuel pump
good luck dude
hope it fix your problem
