Best Oil Filter for my 400?
Old 03-04-2010, 04:15 PM
JBradley500's Avatar
JBradley500
JBradley500 is offline
Originally Posted by Richards73
i only use motorcraft filter for my truck
FL1A...yep
Old 03-04-2010, 05:31 PM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
Anything is fine to use, as long as it's not the orange can of death.
The following users liked this post:
Old 03-04-2010, 06:14 PM
79FordBlake's Avatar
79FordBlake
79FordBlake is offline
I don't reccommend anything but the FL1A Motorcraft.
Old 03-04-2010, 06:33 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
And another vote for the FL-1-A Motorcraft Filter.
I also use motorcraft fuel and air filters as well.
Old 03-04-2010, 06:37 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Motocraft, which are made by Purolator work for me.
I use Purolator in everything else I own.
Josh
Old 03-04-2010, 08:15 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Bottom line is run what ever filter makes you feel all warm and fuzzy inside (other than a Fram of course ).
Old 03-04-2010, 08:31 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
Napa Gold's here. I've also heard to stay away from Penzoil. But, I've never used it, so take that for what it's worth. I also use a quart of Lucas with every oil treatment to provide more lubrication so my cam doesn't flaten out.
Old 03-04-2010, 08:50 PM
4x4 Bart's Avatar
4x4 Bart
4x4 Bart is offline
To change the subject slightly, you know not to use most automotive motor oil without a zinc additive or you will ruin your camshaft. Thats why a lot of folks are using Rotella T.
Hey, I didn't hear about it until I ruined two cams.
Don't take my word for it, ask you local engine builder or search on the internet.
They quietly took the zinc additive out of oils a couple of years ago because it was coating the catalytic converters and eventually stopping them up.
Old 03-04-2010, 08:54 PM
Bricktop50's Avatar
Bricktop50
Bricktop50 is offline
You guys will say I'm crazy but, cut open a Walmart Supertech. Then compare it to a K&N. You will be blown away.
bucks77ford
That was exactly what I was thinking and why I use Lucas. I would use Rotella T, but only seen to find it in 15-40 and I would rather have 10-30. I also would like to use Valvoline synthetic VRI (which still has zinc), but again the only weight I can find around here is 20-50 and I don't have a race engine. I'd have to order 10-30. So Valvoline synthetic with a quart of Lucas additive will work.
Old 03-04-2010, 08:57 PM
Jermafenser
This only applies to cheap new aftermarket cams.
Old 03-04-2010, 09:55 PM
zaaac's Avatar
zaaac
zaaac is offline
Cool, I happen to have rotella t in mine. Not because I knew that, just because it was free. My worn out engine doesn't seem to mind 15-40.
  #28
Old 03-04-2010, 10:15 PM
grandpa'sprideandjoy's Avatar
grandpa'sprideandjoy is offline
I am going to put a motorcraft in the horse for oil filter cant get anything else in motorcraft unless I go to ford dealer in town and probably would be scared by the price
  #29
Old 03-04-2010, 10:17 PM
bucks77ford
I wouldn't say Comp Cams are that cheap, but who knows. I guess I'd rather be safe than sorry when I have an expensive motor.
  #30
Old 03-04-2010, 11:12 PM
Bullitt390's Avatar
Bullitt390
Wal_mart "sometimes" carries Rotella 10w30, but your best bet is to find a Heavy Truck supplier as a lot of the newest Tier III diesels are specing 10w30 so are the new super duty trucks, the 6.0, 6.4 and 6.7 are all 10w30 for winter oil changes.
Josh
Quick Reply: Best Oil Filter for my 400?
