PS pump leak
Old Mar 5, 2010 | 09:33 AM
sncstealth's Avatar
sncstealth
is there a specific size
Old Mar 5, 2010 | 10:18 AM
jjarboe01's Avatar
jjarboe01
in that pic its showing the leak coming from behind the outer fitting, which is indicative of the hose going bad in that fitting. Of the three F150's I've dealt with having this hose, all 3 were bad at this fitting and had to have a new hose put on.
Old Mar 5, 2010 | 10:22 AM
sncstealth's Avatar
sncstealth
okay ill just replace the hose
Old Mar 5, 2010 | 04:10 PM
EPNCSU2006's Avatar
EPNCSU2006
You can get a re-seal kit at NAPA for about 7 bucks that has all the o-rings and shaft seal.
There does look like fluid between the hard-line of the high pressure hose and the hold down nut, which a new hose will fix. However, if it is also leaking between the big adapter fitting and the reservoir, a new hose will not fix that problem.
Old Mar 5, 2010 | 11:45 PM
sncstealth's Avatar
sncstealth
your right i asked to look at the line at advanced and decided it wont help napa here i come
Old Mar 10, 2010 | 07:44 AM
sncstealth's Avatar
sncstealth
okay well im gonna go replace it is there anything i should do special or just un do the line and go with it
Old Mar 18, 2010 | 04:11 PM
Bronco Mann's Avatar
Bronco Mann
Hey just to let you know i have the cluster with the tac . Email me at TMANNONE@comcast.net It came out of a 94 bronco .
