Heat
Old Jan 21, 2003 | 08:03 PM
RMOREY's Avatar
RMOREY
Question Heat
I have a 1995 f150 i've changed radiator, water pump thermostat and heater core and blend flap door is working
Old Jan 22, 2003 | 06:38 AM
Bob Ayers's Avatar
Bob Ayers
Heat
Did you check the heater control valve????
Old Jan 22, 2003 | 07:23 AM
kioolt's Avatar
kioolt
Heat
The following information is from a Ford service CD for a 94 F150 with AC.
Temperature is controlled by a manually operated air blend door in the heater air plenum chamber. When the temperature control **** is in the extreme COOL position (fully counterclockwise) all air bypasses the heater core.
When the temperature control **** is moved to the extreme WARM (fully clockwise) position, all air is directed through the heater core. When the temperature control **** is between COOL and WARM (between full counterclockwise and clockwise), air is directed through and around the heater core in rough proportion to the position of the temperature control **** between the extremes of its travel.
