Pretty sure you'll find its ford's corperate rear-the sterling rear. To the best of my knowlege dodge is the only company to use danas. Go to randys ring & pinion. Its a helpful site.
If you read throgh the Dana specs in the link above it should give you the information you are looking for, that is the only Dana 70 literature on the Dana site..
Thanks for the link, I'll go out tomorrow and get the numbers off it. I'm debating on whether or not to swap it for the sterling in my 85.
I would agree that it most likely originally came with a 10.25". If it indeed has a 70, it was swapped. They quit offering rear Dana axles after '85 except for the F Super Duty trucks.
From my understanding Ford used Dana axles until the mid 85 model year, then they introduced the Ford 10.25.
Dana fill plugs are located in the diff. cover, while Ford 10.25 fill plugs are in the differential housing on the driver's side.
The best I.D. is that the Dana 70u has a smooth pumpkin with no ribbing.
I've also got a Dana 70-U in my F350 Dually. I've done a lot of reading about this axle and it doesn't impress me. It's got a 10.5" ring gear (.25" larger than the Ford 10.25), 1.5" axle shafts (Same size as Ford 10.25), and 35 Spline axle shafts (same as ford 10.25).
However, internet sources have said the carrier itself is not a true Dana 70 size, more like a Dana 60 size...thus creating a weak link. With the smaller carrier comes smaller carrier bearings.
I don't see a large selection of aftermarket Ford 10.25 axle shafts, where as Dana axles have a decent sized aftermarket...which points out the Ford 10.25 has REAL strong axle shafts in stock form. It supposedly has a unique O-Ring on the axle shaft to help retain the gear oil better than other axles.
For what it's worth, I plan on swapping my Dana 70u OUT in favor of a Ford 10.25. The Jeeps and hardcore 4x4 guys seem to like the Dana 70u because the smooth pumpkin glides over rocks or other obstructions.
