my gears, guess what!!!!!!!!
#31
#32
Yes.. but that use is in a vehicle that doesn't have an overdrive transmission. Here are some numbers for comparison. With 28" tires, 3.08 gears and a 3-speed trans the engine is turing just over 2000rpm at 55mph.. assuming no TC slippage. With an overdrive trans like the AOD/AODE/4R70w that same combo needs 4.56 gears to achieve that same engine speed in OD!
So for anybody that has a 5.0 truck with 3.08 gears keep it out of OD unless you're cruising on a flat freeway.. it will actually return better milage.
#34
Calulators from www.4Lo.com
Calculator shows that would be just right if you were traveling at 70mph, not that I don't trust you. Is your speedo set right? I would never want 4.10s/4.11s if I was turning those rpms. Maybe you just need bigger tires.
#35
#36
speed is 60mph
axle ratio is 4.11
E4OD OD ratio is .71
I'm showing 1898rpm there. The 300 should be happy as a lark.
#37
#38
#39
#40
When I first got my 95, I would run 20 miles at a time over 100mph. That was with 3.55 gears. I'm sure 3.73 could do it, but who really drives like that? Where do you live? What are the grades like and how do you drive? 20mpg. And unlike my tastes in baskets, hand calculated doesn't do anything for me in mileage. How do you calculate?
#41
Did you reprogram your PSOM for the 31s. I really probably should do that to mine.
#42
I will say the 300 and 4.11 is really nice around town though. Too bad we can't split the gears somehow. I know this sounds stupid, but I almost wish I had something like a 4x4 system.. 3.00 in the front axle, 4.56 in the rear. Lock out the front axle going around town, then reverse the two going on the highway.
I know I know, you're thinking "No dude, that's just stupid", but I bet it would really make a good econo-truck.. Plus, if you needed to pull a heavy load, you have the gearing for it.
I never did, but my speedo is spot on and my transmission shifts "fine". Is your speedo correct???
#43
I know, it should be, that's the middle of the powerband. It was happier with the 3.08 on the highway.
#45
