Oil Temp Gauge?
Old Mar 2, 2010 | 10:40 PM
Mrfun2fly's Avatar
Mrfun2fly
Oil Temp Gauge?
Any reccomendations for an Oil Temp Gauge? and where do I install it?
Thanks,
Old Mar 2, 2010 | 10:48 PM
rickatic's Avatar
rickatic
I get my temps from my Edge Insight. Works great and easy install. Watches a lot of other pid's as well
Old Mar 2, 2010 | 10:54 PM
texans's Avatar
texans
I like isspro gauges. As far as I know just about the only way to get the temp is from the filter cap. You have to buy a billit cap with the port on top for the sender. You could also get it from the test port on the front. But that would require some addapter and alot more work.
Old Mar 3, 2010 | 12:02 AM
Randy777's Avatar
Randy777
I have Isspro gauges too and they work great. I drilled a hole in my oil pan for the sensor. After drilling the hole I changed the oil and put a small magnet into the oil pan to get any metal pieces out. I sealed around the sensor with J B Weld. It has not leaked in four years. I also did this with my other truck. I have found the oil temp gauge gives more information on the engine than my Isspro water temp gauge. To me a must for towing.
got2befast
Jul 17, 2010 07:10 AM
missouguy
Jan 27, 2005 01:07 AM
bigolbob
Nov 11, 2003 04:07 PM
unaFORDable
1997 - 2003 F150
Jan 28, 2000 12:52 PM
deleontow
Jan 14, 2000 08:55 PM
