New Owner Introduction
Old Mar 7, 2010 | 02:04 PM
abe's Avatar
abe
Originally Posted by Randy Jack
BTW, 53 grills don't have teeth.
I think he means the chrome "teeth" (they are about 1"-2" high) that the deluxe cabs have on the grille.And, yes they are reproduced and sometimes you acn find NOS on ebay for sale.
Old Mar 8, 2010 | 02:09 AM
Old School 53's Avatar
Old School 53
Yeah, thanks. I was talking about the chrome teeth in the '53 grille. My grille has holes for them, so I guess it's a deluxe cab. I did find a '56 grille along with a tailgate and other needed parts, so I may just swap that in. This truck isn't pretending to be original anyway.
From looking through parts catalogs, it seems like there's a separate wiring harness for the headlights and indicators that's supposed to plug in somewhere on the inner fender? I'm asking because it seems that there's been some amateur wiring done on this truck. My wiring for all the lights comes from the firewall to the driver's side headlight and indicator, then splits and goes to the passenger headlight. There is no connector for the passenger side indicator. There is one stray wire but the connector is totally different than the plug on the indicator. I'm thinking it could be for the horn. Is there something I'm missing here or do I need to get out the voltmeter and do some legwork?
Old Mar 8, 2010 | 02:19 AM
Julies Cool F1's Avatar
Julies Cool F1
Just swapping in the 56 grill isn't going to be as easy as you think - wind break panels are different I think.
Wiring headaches? Take a look at my drawings in my #4 gallery. Those might help.
Old Mar 8, 2010 | 11:06 AM
AXracer's Avatar
AXracer
Yes, you will need to swap to the 56 wind deflector panels on either side of the radiator mount since the 56 headlight buckets sit further back. It's a bolt in swap tho.
"Amatuer" wiring is a common situation on our trucks. Most of the time a complete rewiring is highly recommended either replacing the stock 50 year old wire and all the PO (previous owners) "modifications" with new wire and connectors if you are not planning (m)any electrical additions, as Julie and other near stockers advocate, or adding a new aftermarket modern fuse panel and wiring kit such as offered by EZ Wire as us darksiders prefer, each option has pros and cons. The last recommendation you'll see tho is buying a stock replacement wiring harness, as unless you are after a 100 pt. restoration, they are very overpriced and inflexible. See the frequent wiring topic discussions.
Here's a link to the stock 56 12V wiring and 53-55 6V wiring diagrams on Earl's World to get you started.
http://www.clubfte.com/users/earl/Re...rial.html#1956 Truck Wiring Diagrams
Old Mar 9, 2010 | 07:35 PM
lbrauer's Avatar
lbrauer
Welcome to the thread. You will find a lot of information on this about your truck and many others from the most informed people in the world. My name is Larry by the way.
Old Mar 9, 2010 | 07:59 PM
sparky's Avatar
sparky
Well belated welcome, sorry I have been away for a while, gotta love that nailhead...sort of screams hotrod... and some of us love the rodder scene Wiring is not something to be overlooked, especially if it is suspect, flames look good on the fenders but not real ones replacing the entire truck's wiring is not as hard as it appears with the right help, patience, time and planning. You will always find some helpful advice here I am sure
