which motor oil?
Old Mar 2, 2010 | 08:41 PM
bass3006's Avatar
bass3006
which motor oil?
Just bought an 08 XLT with the 5.4L and only 10,500 miles! Just wondering what I should be using for oil in it. Should i use standard stuff or the full syn? Also considering using standard with an additive like Lucas, Prolong and such. I do change at regular intervals. I do plan on using only Motocraft filters.
Also, anyone have experience with royal purple?
Old Mar 2, 2010 | 09:12 PM
Ryan50hrl's Avatar
Ryan50hrl
You'll get about 1.4 million different opinions on this.....the general consensus is semi-syn motorcraft blend oil in 5w20 and motorcraft filters.......
Old Mar 2, 2010 | 09:53 PM
bridge's Avatar
bridge
Sick 'n Tired
Indeed, search for the 1.4 opinions. But, in the end it doesn't really matter. Just use a motorcraft filter and change it at the user manual recommended interval.
A good rule of thumb but by no means a rule:
Conventional oil gets replaced every 3000 miles
Semi-syn gets changed every 5000 miles
Full syn gets changed every 7000 miles
Pick your favorite brand...
Old Mar 2, 2010 | 10:30 PM
Roller150's Avatar
Roller150
Change the oil 5-7000 miles and use 5/20. Go with any major brand and you will be ok. I just dont get why this is so hard for people to get. Not trying to dog you here but its amazing how many topics are on this subject.
Old Mar 2, 2010 | 11:07 PM
pb34's Avatar
pb34
I stick with full syn and choose whatever brand is cheapest or on sale. I've never had any problems with it so I that's what I'll keep doing!
Old Mar 2, 2010 | 11:42 PM
bass3006's Avatar
bass3006
sounds simple enough, thanks 5w20 w/ motorcraft filters
Old Mar 3, 2010 | 02:59 AM
Gearbanger 101's Avatar
Gearbanger 101
Had a pretty good debate going on about it in this thread a couple of months back. Interpret and follow said advice as you see fit.
https://www.ford-trucks.com/forums/9...-question.html
Old Mar 3, 2010 | 09:50 AM
1Aauto's Avatar
1Aauto
Former Vendor
I've had good luck with Mobile 1.The Motorcraft filters are good too.
Old Mar 3, 2010 | 06:20 PM
jwillyf150's Avatar
jwillyf150
I'll tell ya this, I've been running MC 5/20 since I got my truck and have always had a ticking noise between 1100- 1500 rpm. Well I switched to high mileage 10w30 castrol with MC 820S filter and no more ticking noise. 5w20 just too light for higher mileage vehicles IMO. Just my .02 carry on.....
Old Mar 3, 2010 | 07:51 PM
baitmaster's Avatar
baitmaster
Pick your poison, I personally run full syn in all of my vehicles. Get it on sale, more miles between changes, and your total cost isnt that much dif. Once read a report on oil testing, in every category except price, the syn outperformed. If you only keep a vehicle a few yrs, run the cheap stuff. I drive mine into the ground, so I like to get a lot of miles on them before they go bye-bye. Never had a oil related motor prob.
Old Mar 3, 2010 | 08:09 PM
dan291000's Avatar
dan291000
Mobil 1 5-20 Full Syn./ Motorcraft filter all available at your nearest Wallyworld...
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
dan291000's Avatar
dan291000
Disregard......
Old Mar 3, 2010 | 08:10 PM
dan291000's Avatar
dan291000
Disregard..........
dan291000's Avatar
dan291000
Disregard.........
Old Mar 4, 2010 | 08:57 AM
1Aauto's Avatar
1Aauto
Former Vendor
The way I look at it is that the synthetic is actually cheaper than the cheap oil. It improves gas mileage,wear and tear on the motor,you get twice the distance between oil changes.
